ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
halmi
28 Jan 2021 11:49
How quickly did you reach 55-60% again?
Alessandro
28 Jan 2021 11:53
I would estimate that this will happen within 4-5 hours.
Z
Zaba12
28 Jan 2021 11:57
halmi schrieb:
How quickly did you get back to 55-60%?
Does that really matter? 55-60% is perfectly fine for a bathroom without controlled mechanical ventilation. It doesn’t have to be 45%. As a "recommendation," you will find various sources suggesting somewhere between 50-60%. Only those of us with controlled mechanical ventilation have extremely low levels like 35-45% or even less.
Ötzi Ötztaler
28 Jan 2021 12:25
Alessandro schrieb:
Maybe it’s normal, I don’t know.
That’s how it sounds to me at first. Just make sure to ventilate regularly and that should be fine. If the humidity is around 60% in winter, just open the windows again.
halmi
28 Jan 2021 12:47
Zaba12 schrieb:
Does it matter? 55-60% relative humidity is completely normal for a bathroom without mechanical ventilation. It doesn't have to be 45%. As a "recommendation," you can find ranges anywhere between 50-60%. Only we with mechanical ventilation have extremely low humidity levels of 35-45% or even less.
That was just a question, but considering the timeframe, I don’t think there’s anything broken or leaking in the bathroom.
Lumpi_LE
28 Jan 2021 12:51
Especially if there is no controlled residential ventilation, this is completely normal. Where do these concerns even come from?
At your parents’ place, something is simply not airtight—whether it’s the windows, doors, or wastewater/ventilation pipes—there are many possibilities.
