ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
netuser
12 Mar 2021 09:14
Bookstar schrieb:
It also affects my diet negatively; mostly hot soups have ended up on the lunch menu ever since.
I’ll put it this way: I sympathize with you, but only to a limited extent.
With such an irresponsible action on your part, you should be grateful you’re not restricted to bread and water until the bathroom reaches 24°C (75°F) again and the rest of the house returns to a comfortable temperature. The latter created by frictional heat when you crawl around the house on your knees before the authorities! 😉
Z
Zaba12
12 Mar 2021 11:09
I am a bit speechless when I read that 20.9 degrees Celsius (69.6°F) is considered the end of the world. Well, everyone gets what they deserve 😎 and chooses for themselves :p
FF2677
12 Mar 2021 11:23
Zaba12 schrieb:
I'm a bit speechless when I read that 20.9 degrees Celsius (70°F) is considered doomsday. Well, to each their own 😎 and what they deserve :p
For us, it's already doomsday below 23°C (73°F) :p
Had a lawyer check it, it was actually in the fine print at the wedding ceremony 🙂
Malz1902
12 Mar 2021 11:33
We have temperatures between 23-24°C (73-75°F) in the bathroom and around 22-23°C (72-73°F) in all other rooms.
The compressor outside has now been running continuously for 3 days without shutting off once. The outdoor temperature averages 6°C (43°F) over 24 hours.
halmi
12 Mar 2021 11:41
Yesterday, we checked our values. From mid-October to mid-March, our electricity consumption is about 2200 kWh, which generated approximately 9400 kWh of heat (heating + hot water), resulting in an efficiency factor of around 4.25. If I also include the transitional periods and hot water consumption in summer, the annual consumption comes to about 2800-2900 kWh. Roughly 12-15% of this is produced by the photovoltaic system.
I’m very satisfied; the winter was noticeably colder compared to recent years.
Malz1902 schrieb:
The bathroom is between 23-24°C (73-75°F), and all other rooms are around 22-23°C (72-73°F).
The compressor outside has now been running continuously for 3 days without turning off once. The 24-hour average outside temperature is 6°C (43°F).
Your heat pump seems to be a perfect fit. Mine doesn’t go down that far. Currently, it usually runs about 10-12 hours on and 10-12 hours off. The hysteresis is only 1°C (2°F).
Bookstar
12 Mar 2021 12:46
halmi schrieb:
Yesterday, I checked our consumption values. From mid-October to mid-March, we use about 2200 kWh of electricity, which produces around 9400 kWh of heat (heating + domestic hot water), resulting in a seasonal coefficient of performance (COP) of approximately 4.25. Including the transitional periods and summer hot water, our annual electricity consumption comes to about 2800–2900 kWh. Roughly 12–15% of that is produced by the photovoltaic system.
I’m very satisfied, especially since this winter was noticeably colder compared to recent years.
Your heat pump seems to be a very good fit. Mine doesn’t get as efficient. At the moment, it usually runs for 10–12 hours on and 10–12 hours off, with a hysteresis of only 1°C (34°F).
For that period, our electricity consumption is around 3300 kWh.
@above: I find 23 to 24 degrees Celsius (73 to 75°F) uncomfortable; I don’t even want that temperature inside the house during summer. We consider 22°C (72°F) ideal.
