ᐅ Floor plan design for 4 people, building volume predetermined
Created on: 20 Feb 2023 14:20
Sumi2188
We are a family of four (children aged 4 and 13) and have been trying since 2017 to obtain a building permit for a plot of land owned by my parents, located south of Potsdam.
The main challenge is the location of the property. Since my parents’ house is the last house on the street, the residential area also ends there, and despite having 10 hectares (25 acres) of land, our building options are extremely limited. After a long legal dispute, we have at least secured a preliminary approval for a building permit. However, this comes with the compromise that the new building must be constructed on the current site of an old barn (key point: model effect when building in rural areas) and must adhere to the barn’s existing volume. We need to demolish the barn and then build our new home on that spot, which means we have very strict requirements for the floor plan.
We have had an official site plan prepared. Since our original plan (an L-shaped bungalow) was basically the opposite of the current planning, I would be very grateful for any advice on room layout and orientation, as I have not found a good approach so far. The barn’s footprint can only be shifted along the axis to the extent that the property boundaries do not overlap. According to the building authority, a wall thickness of 25 cm (10 inches) is allowed as an increase in volume, but any further enlargement (bay windows, altered roof pitch, etc.) is not permitted. Our equity amounts to around 250,000 €.
We already have a planning meeting scheduled with an architect (March 1, 2023), but it would be great to get some ideas here on what we should consider beforehand. Perhaps someone has similar dimensions and ideas on how to create a nice floor plan.
Zoning/Restrictions
Plot size: Currently not fixed. Between 2,000 and 3,000 m² (22,000 and 32,000 sq ft), but the buildable area is fixed.
Slope: No
Style, roof type, building type: Predefined
Basement, floors: No basement
Number of occupants, ages: 4, two adults and two children (4 and 13 years)
Room requirements on ground floor and upper floor: Predefined
Office: Family use or home office? Originally planned to include an office (husband is a teacher), but there is currently an alternative that can still be used. An office would be nice but only if it does not significantly reduce space for other rooms.
Guest bedrooms per year: Not relevant
Open or closed architecture: Open-plan living/kitchen, otherwise closed
Conventional or modern style: Rather conventional
Open kitchen, island: Open-plan living/kitchen, an island would be great.
Number of dining seats: 6
Fireplace: Yes
Music/stereo wall: Not relevant
Balcony, roof terrace: No
Garage, carport: Already available
Vegetable garden, greenhouse: Not relevant
Other wishes / special features / daily routines, including reasons why certain things should or should not be included
Site plan of a building plot with barn, parcels, and a house cross-section.
Thank you very much
Sumi
Schorsch_baut
21 Feb 2023 22:28
You could skip the closet in the hallway by the stairs and instead place the door to the utility room there. That might also leave space for a shoe rack.
K a t j a21 Feb 2023 22:51
Schorsch_baut schrieb:
You could leave out the closet in the hallway by the stairs and instead place the door to the utility room there. That might also create space for a shoe rack.
I’m afraid the headroom wouldn’t be sufficient for that. But it was just an idea to make use of the space all the way up to the ceiling. Perhaps a standard layout would be enough for the original poster, as there are tons of examples. Just try searching for 120m² (1,292 sq ft) floor plans or, even better, browse through the well-known modular home providers.
Schorsch_baut
21 Feb 2023 23:20
K a t j a schrieb:
I’m afraid the headroom isn’t sufficient for that. But that was just an experiment to make full use of the space up to the ceiling. Maybe the original poster is fine with a standard layout anyway; there are plenty of examples out there. Just try searching for 120 sqm (1300 sq ft) floor plans or, even better, check out the major prefab house manufacturers.
You don’t need to access the utility room as often, so the door there can be narrower and/or lower. Similar to basement access doors in older houses.
11ant21 Feb 2023 23:35
You don’t need to access the utility room that often, so the door can be narrower and/or lower.
The boiler should still be able to fit through the door ;-)
Schorsch_baut
21 Feb 2023 23:39
Depending on the technology, the systems are not that large, and you can also install an exterior door. I would prefer not to restrict the living room corner with access to the utility room.
prm2021
21 Feb 2023 23:53
K a t j a schrieb:
I’m afraid the headroom won’t be sufficient for that. But that was just a bit of experimentation to see if the space could be used all the way up to the ceiling. Maybe the original poster would be satisfied with a standard layout; there are plenty of examples out there. Just try searching for 120m² (1300 sq ft) floor plans online or, even better, browse the offerings from well-known prefab home manufacturers.
It’s hard to find a really good floor plan for a smaller house without a basement online.
Perhaps consider optimizing and slightly enlarging the Raumwunder 114.
