ᐅ Floor Plan Optimization – Semi-Detached House Approximately 150 sqm
Created on: 19 May 2022 16:40
KleinUndFein
I’m new here and would appreciate your ideas. We are planning a 150 sqm (1,615 sq ft) semi-detached house and are looking for the optimal floor plan.
Development Plan/Restrictions
The building envelope is used to its full extent.
Builders’ Requirements
- As clever a floor plan as possible
- The house will be occupied by two adults and two children (4 and 6 years old)
- The ground floor and upper floor should be able to be lived in separately (aging in place)
- No overly extravagant or expensive features should be used
- Basement with a technical room is available
- Prefer architectural style and conservative construction methods
- Open kitchen, but more of a kitchen-living area. The “living/media area” should be part of the kitchen-living space
- Are there better ways to use the space and are the room sizes suitable for normal use?
- Does the layout suit a family and two living units for the future?
KleinUndFein
22 May 2022 13:11
Einplan schrieb:
I would strongly recommend everyone to simulate their floor plan in 3D using a free program like Home by Me! It saved us from disastrous mistakes.
When you furnish the rooms with the program, you immediately get a sense of the dimensions.
Thanks, we have already been shown this and thought it wasn’t bad. Having the dining table in front of the patio door is obviously a bit suboptimal. But you can still get outside. Also, the table drawn in is too large.
22 May 2022 13:20
KleinUndFein schrieb:
What is your suggestion? Saying "bathing in an agricultural property from 1960" is quite a bold statement without any explanation or a better alternative. What would you do differently?
… nobody wants to waste hours on a plan if the basic conditions are not known. You have been asked multiple times from different people to provide a site plan, a Google Maps view, the dimensions of the plot, and information about the neighborhood here. You have not complied.
For the third time: no arms, no cookies.
Meaning: no information, no suggestions.
11ant22 May 2022 13:23
It shifted while tracing.
Instead of tracing, scanning or photographing would be the solution. For example, I really don’t believe in the different types of interior walls in the architect’s plan as they were “traced.”
The comment about “bathroom in an agricultural building from 1960” is really quite harsh.
Harsh, but accurate.
What’s interesting is that everyone has criticized it now, but hardly anyone is making a suggestion.
No, not interesting. Rather the obviously causal result of a poor and poorly documented plan, which has only been explained bit by bit. We still haven’t seen the existing basement :-(
KleinUndFein
22 May 2022 14:39
… nobody wants to waste hours on a plan if the prerequisites are unknown. You have been asked multiple times from various sides to provide the site plan, Google Maps view, property dimensions, and neighborhood details here. You haven’t complied.
Just briefly explain what you need this for? I simply don’t understand. The exterior walls are fixed, you know north. The location of the other half is probably clear as well? Everything else is set and beyond the scope of the question.
So your cookies will most likely remain with you.
By the way, “no arms, no cookies” is rather in poor taste. There is a war raging in Europe right now, good sir!
WilderSueden
22 May 2022 15:10
What’s interesting is that everyone has criticized it now, but hardly anyone has made a suggestion. I’m starting to believe that everyone here is thinking too narrowly within their own ideas, and that it’s impossible to develop a joint design.
A really good alternative floor plan has already been developed here several times with considerable effort. However, this requires seeing the floor plan not just as a minimal change to the original but as a development within the given parameters. Since you still haven’t clearly and completely outlined these parameters, you won’t receive any meaningful proposals.
Your feedback “we’ll take this to the architect” also shows that you want to address the problems in isolation rather than holistically. Ultimately, you won’t be able to avoid this. As soon as you move walls, the other rooms automatically change as well.
KleinUndFein
22 May 2022 15:52
WilderSueden schrieb:
There have been several efforts here to develop a truly good alternative floor plan with a lot of work. However, this requires viewing the floor plan not just as a minimal change to the original, but as an evolution within the given parameters. Since you still haven’t clearly and completely listed these parameters, you won’t get a reasonable proposal.
Your feedback “we will take this to the architect” also shows that you want to address the issues in isolation rather than holistically. In the end, you can’t avoid it. Once you move walls, the other rooms automatically change as well.
Hello WilderSüden,
That sounds good and I understand the ambition behind it. But it’s not really what I’m looking for. What helps me is an example floor plan I can learn from or 2-3 tips. Not the full range of offerings. That just helps me a bit.
I find it strange when one person decides who gets what or not. If I don’t get the small tips here because no one wants to share, that’s okay. But you can say that politely. We’re not in prison here, are we? 🙂
By the way, a 1960s farmhouse is actually fine. It just should not be too cramped or ill-conceived.
