ᐅ Glass sliding door with recessed handle and separate pull bar
Created on: 30 Apr 2021 11:46
bauenmk2020
bauenmk202030 Apr 2021 11:46
I am currently requesting quotes for glass sliding doors. Due to the small distance between the door and the wall (the door runs along the wall) and because the offer includes the door and the track housing as an inseparable unit, there is only one recessed handle on both sides. The door separates the hallway from the living/dining/kitchen area and will probably remain open most of the time.
Has anyone had experience with adhesive handle bars for glass doors?
hanghaus2000
30 Apr 2021 12:05
Unfortunately not. The handles are screwed on. This results in spacers between the handles and the wall.
See pictures.
Door handle on glass door, next to a musician sculpture and a green potted plant in a black pot.
Modern interior shot: glass partition with metal handle, red armchair and plant in the background.
caspar.1
2 May 2021 10:25
bauenmk2020 schrieb:
The door separates the hallway from the living/dining/kitchen area and is probably open most of the time.
Then a pocket door like the one we have ..... is probably the best option 😉 We also initially considered a pull bar handle, but we like it better without one, and as you said.... the door is usually open anyway 😉
Modern kitchen with gray high-gloss cabinets, tiled floor, and glass partition in the foreground.
hanghaus2000
2 May 2021 10:29
caspar.1 schrieb:
Then a shell-shaped shower like the one we have ..... is probably the best option 😉 We also initially considered a grab bar but we like it better without, and as you already said.... the door is usually open 😉
Is it double-sided and glued?
I really like it.
In our case, the door is almost always closed. So it gets used several times a day. In that situation, a grab bar is definitely the better solution.
caspar.1
2 May 2021 10:42
hanghaus2000 schrieb:
Is it bonded on both sides?
No, there is a hole in the glass... it is screwed in.
However, I think bonding is just as strong and also looks better 😉
The door can be easily opened with the recessed handle, and closing it is very smooth.
Close-up of a glass door with metal handle, view of a tiled hallway
Flat, square metal handle with recessed grip on a light blue door.
hampshire
2 May 2021 11:09
First decide on the more practical opening width, then choose the type of handle. We preferred a bar handle and made the passage slightly wider to accommodate it.
