ᐅ KALLAX Glass Doors – Has Anyone Installed These Before?
Created on: 25 Jul 2020 08:37
GAUTAN
I am considering upgrading my IKEA KALLAX shelves with glass doors. More specifically, I am thinking about the best way to install glass doors on the KALLAX units, which types of glass are suitable, and what to watch out for during installation.
Has anyone here ever built or fitted glass doors for KALLAX? What are your experiences regarding stability, visual effect, and usability? I am especially interested in whether it’s feasible to make the doors yourself or if it’s better to use prefabricated accordion or pivot doors.
I look forward to all your feedback and helpful tips!
dunitan
26 Jul 2020 13:03
Hello @GAUTAN, regarding the adjustments: hinges with multiple adjustable axes are extremely valuable. They allow precise alignment of the door in height, width, and depth, so soft-close mechanisms can be installed directly.
A proper drilling template set for the hinges can also help ensure the mounting holes are perfectly positioned. If the frame does not warp on any side, small irregularities can be easily compensated.
JEREMIAH38
26 Jul 2020 14:11
GAUTAN schrieb:
how you handled the adjustment of the doors
Patience paid off for me. I tested various hinges and eventually chose a model that can be precisely adjusted with an Allen key. This allowed me to keep the gaps to a minimum. A tip: definitely allocate plenty of time for alignment, otherwise it can get frustrating.
onron schrieb:
small cup hinges with adjustment options make alignment much easier
I agree with that!
Daledra
27 Jul 2020 08:30
I just wanted to add that for my project, I had glass and aluminum profiles cut at the home improvement store. This saved me a lot of work.
If you use glass, be sure to pay attention to the edges – they should be properly beveled to prevent injuries.
Kabau
27 Jul 2020 09:47
Daledra schrieb:
Had glass and aluminum profiles cut at the hardware store
I can also recommend that. If you don’t have the tools, getting the cuts done there is convenient, and the staff are usually helpful.
Z
zartra
27 Jul 2020 12:21
One more pro tip: Since the inside of the KALLAX is often veneered, it can help to reinforce the screw holes with wood glue or small dowels before assembly. This way, hinges hold better and rattling is prevented.
Rashadmeo
27 Jul 2020 14:55
I just wanted to say: If you read this first and then get started, you really can't go wrong. Good luck with the project, they are truly a great visual enhancement for any room! 🙂
