ᐅ Initial planning for a single-family home with a granny flat on a 600 m² plot
Created on: 2 Jan 2021 15:34
Grand90
Grand90
2 Jan 2021 15:34
after a long search, we have purchased a plot with an existing building and are now at the very beginning of the planning process. The handover of the house is on January 4th.
A meeting with an architect is scheduled in two weeks, but it’s good to already have some preliminary thoughts beforehand 😉.
The surveyor will also come soon to create a site plan with elevation points.
Here are the facts:
Plot size: approx. 600 m2 (13 m x 47 m / 43 ft x 154 ft) currently with a building worth demolishing.
Slope: Yes, descending from east to west (ground floor fully into the slope, first floor partially).
There is no formal development plan, but the existing houses all have 3 full storeys.
On the west side runs the old main road, and further away the federal highway.
To the north is a neighboring building, to the south the garden of the plot. The plan after demolition is to shift about 5 m (16 ft) to the south to gain some distance to the neighbor, parking spaces and a terrace for the granny flat.
The sun shines on the property all day. As far as I know, there is no shading.
Builders’ requirements
Style, roof type, building type: Regular single-family home with granny flat and pitched roof
Basement, floors: No basement, 3 full floors
Number of people, ages: Currently 2 adults (30 and 25 years old), planning 2 children. Rented granny flat (max. 2 persons). The granny flat should serve as a retirement home and therefore be on the ground floor, step-free.
Space requirements on ground floor and upper floor: see draft
Office: Possible home office as well as family space
Guest sleepers per year: Occasionally, on average every 2 months for one night (currently sofa bed in living room)
Open or closed layout: Good mix
Conservative or modern construction: Rather conservative
Open kitchen, kitchen island: Kitchen and dining room combined, living room separate
Number of dining seats: 8-10
Fireplace: Rather no, does not make much sense with KFW55 standard, heat pump, and underfloor heating. Possibly ethanol fireplace?
Music / stereo wall: Yes
Terrace: Yes, on ground floor next to the granny flat parking spot, and on the first floor above the double garage (question whether to use the entire double garage roof as terrace or maybe extend the dining area a bit)
Garage, carport: Double garage and double parking space
Utility garden, greenhouse: Possibly later
Additional wishes / special features / daily routine, also reasons why certain things should or should not be:
Separate living areas so that when guests visit one half or later the children, there is no disturbance.
Who designed the plan: myself
No large wasted hallway area. Our current apartment has a large almost unused hallway.
What do you dislike? Why?
- Floor plan of the granny flat quite uncertain, especially the bathroom placement. With controlled ventilation, the bathroom could actually be windowless, but I would prefer a window. The location of the bathroom affects the layout of kitchen/living/dining areas.
- The two L-shaped children’s bedrooms on the second floor are a compromise to avoid a too-large hallway.
Price estimate: my own estimate is €650,000
Personal price limit for the house including fittings: still needs to be clarified with the bank. The plot with the existing building was purchased with equity.
Preferred heating system: Ground-source heat pump with deep drilling and underfloor heating. Photovoltaics on both roof sides (east-west orientation). Controlled domestic ventilation with heat recovery. Blinds to be planned for shading.
If you had to give up, which details / extensions
- could you do without:
- cannot do without:
Why did the design turn out as it is now?
Initial drafts based on our requirements and space needs to define things for the first meeting with the architect.
At the current planning stage:
Review of floor plans and tips based on users’ experience. Possibly identify incorrect house or room placement, point out no-gos. No detailed or thorough assessments necessary as the architect’s plan will change things later.
Explanation of the floor plan:
The walls are not depicted precisely yet. Therefore, the rooms will actually be smaller. Windows and furniture are currently randomly placed. You might also have tips here.
Ground floor: Here will be a solidly built granny flat plus a utility room in the house as well as a double garage with basement and small workshop.
Between the house and the double garage there will be an external staircase leading to the first floor. The house entrance is planned to be on the hillside side at the first floor level.
1st floor: Here a 2-storey single-family home in timber construction is planned. The double garage roof is to be used as a terrace.
Rooms on this floor: spacious kitchen-dining area, separate living room, office, and a small bathroom with shower.
2nd floor: bedrooms, main bathroom and a hobby room / guest room.
The allowable footprint of the house is still open. Easements from neighbors may have to be obtained. But I think something like 8 x 12.5 m (26 ft x 41 ft) could be enough.
If you need more information, please let me know 😉.
Feel free to share any concerns. I’m open to all opinions and tips, as we are still at the very beginning of the planning stage.
Thanks and best regards
Florian
Grundriss eines Hauses mit Wohnen, Küche + Essen, Büro, Flur, Bad, Abstellraum und Terrasse.
Grundriss eines Hauses mit Elternschlafzimmer, zwei Kinderzimmern, Bad, Flur, Abstellraum, Hobbyraum.
Grundriss eines Hauses: Wohn/Ess/Küche, Schlafzimmer, Bad, Büro, Garage, Freisitz, Abstellräume.
Grundriss eines Hauses mit Garten, Garage, Werkstatt und Keller.
Langgestrecktes Grundstück mit roter Umrandung entlang einer Straße; Gebäude erkennbar.
Skizze: Nordansicht eines dreistöckigen Hauses links; Ostansicht eines zweiten Hauses rechts.
Architektenzeichnung einer Südfassade eines Hauses mit Terrasse und Geländer.
Lageplan eines Grundstücks mit Gebäuden (Whs), Garagen, Zäunen und Nordpfeil.
Grand90
7 Jan 2021 12:00
Since no one has responded yet, possibly due to the text being too long or unclear, here are the questions in a clear format:
1. Is there a better location for placing the house and the double garage? (I don’t think so because of the narrow, elongated shape of the plot)
2. Does anyone have a better idea for the layout of the bathroom in the ground floor granny flat?
3. Does the room arrangement on the first and second floors (single-family house) work well with the directions of the compass?
Is there anything missing, or is it simply too early in the planning stage for answers?
Thanks and regards,
Florian
kbt09
7 Jan 2021 18:36
Well, if only something could be properly assigned. And if one knew why a 10 m (33 ft) wide house can fit on a 13 m (43 ft) wide plot. What about the usual minimum distance of 3 m (10 ft) on each side? Can the garage be this close to the street?
And if one knew who is supposed to live in such a dark basement apartment. A bedroom without a window? A bathroom accessible only through the living room? Only western light? Who would rent that?
I understand correctly that the ground floor on the east side is basically built into the slope.
Why not simply place the workshop, storage, and utility rooms on the ground floor in the windowless area, and then have an entrance with a spacious wardrobe and a guest/hobby-sports room with a west-facing window?
And then just have generous floors above.
Pinkiponk
7 Jan 2021 18:43
I would ask the architect to plan for larger windows. They seem too small in the house picture.
11ant7 Jan 2021 18:59
Grand90 schrieb:
currently with an old structure worthy of demolition.
Grand90 schrieb:
Since no one has responded so far, possibly due to the potentially too long and unclear text, here are the questions clearly stated:
However, these do not seem to clarify the confusion—I suspect the main reason for the low participation is the lack of clarity in presenting the project. The drawings suggest a complex of two buildings loosely connected. An existing building is described as being fit for demolition, yet the drawings show a building that appears to date back at least to before World War II; I wouldn’t rule out 1970/71 either.
Grand90
7 Jan 2021 19:02
Sorry for the confusion. The two building elevations show the demolition building and are intended only to reflect the slope of the terrain.
Unfortunately, I didn’t notice that the images were renamed during the upload.
Image 1 = 1st floor detached house (or ground floor from the slope side)
Image 2 = 2nd floor detached house
Image 3 = Ground floor with granny flat, utility room, and attic
Image 4 = Plot of land
Image 5 = Aerial view with plot dimensions
Image 6 = Elevations of the old building north + east
Image 7 = Elevation of the old building south
Image 8 = Site plan of the old building (parcel numbers 64, 65, and 66 are included)
