Created on: 27 May 2019 10:48
goalkeeper
Pinkiponk
25 Jan 2020 08:28
Scout schrieb:
This was decided by the Higher Regional Court of Nuremberg in a ruling dated January 30, 2017.
I find it interesting that this ruling is relatively recent. Meanwhile, some people claim that these heat pumps are so quiet that they are no longer audible.
Basically, I believe that anyone who favors this heating method should choose a model they would also feel comfortable placing right outside their own bedroom or children’s room window without any concerns.
kaho67425 Jan 2020 10:40
Scout schrieb:
A neighbor is generally required to remove an air source heat pump if it has been installed less than three meters (10 feet) from the boundary of the neighboring property.
The neighbor will probably want to install a similar device somewhere as well. Their problem is even more significant. If it really does not have to be within the building area and can be placed in front, it would be great to "find a common solution"—as Merkel often says.
kbt09
25 Jan 2020 10:41
There are hardly any other options left on the property.
goalkeeper
25 Jan 2020 11:18
It's not about the neighbors (who all have the same issue), but whether the building authority can require me to keep the outdoor unit within the building setback area, even though this is not explicitly stated in the development plan, or only the part concerning ancillary structures.
Scout
25 Jan 2020 11:35
goalkeeper schrieb:
My concern is not really about the neighbors (who all have the same issue), but whether the building authority can require me to keep the outdoor unit within the building setback area, even though this is not explicitly stated in the development plan, except for the part concerning auxiliary structures.
Regarding the legal classification of this issue, I provided you with an explanation from a lawyer in #966 (last paragraph).
For reasons unknown to me, this post was flagged by an admin—does anyone have an idea why?
11ant25 Jan 2020 11:40
A Google search result points to the green forum (?)
