ᐅ Long, narrow plot of land measuring 170–190 square meters
Created on: 4 May 2019 13:50
Ben-man
Ben-man
4 May 2019 13:50
I would like to hear your opinions about our current planning. The plot is approximately 460 sqm (5,000 sq ft) but trapezoidal in shape. Therefore, we are placing the house along the southern boundary of the plot and putting the garage above it. The plot has already been purchased and paid for. There is no zoning plan, so the following values should be considered as guidelines.
Zoning/Restrictions
Size of building plot: approx. 460 sqm (5,000 sq ft)
Size of garden plot: approx. 600 sqm (6,460 sq ft)
Slope: None
Floor space index: 0.4
Building envelope, building line, and boundary: Hessian regulation, three-meter (about 10 feet) setback
Edge development: Garage only
Number of parking spaces: Two
Number of floors: Two
Roof style: Hipped roof
Design style: Modern
Orientation: ?
Homeowners’ Requirements
House without a basement, but with a large attic
Two adults, one child
The current plan is quite large at about 190 sqm (2,045 sq ft). We are considering reducing the southern side a bit to end up with around 170-180 sqm (1,830-1,940 sq ft).
Office: Family use and home office
Open kitchen, wife wants a breakfast bar
Wood stove (desired but not yet planned)
What was important to us:
- Hallway not too narrow
- Easy to clean (few corners and preferably square rooms)
- An open staircase (even though it is not the best solution energetically)
- Ground floor office should be able to serve as a bedroom in old age
- Lots of garden views on the south side
Designer: Do-it-yourself
Estimated cost according to architect/planner: 310,000 (without garage, windows, shutters, shutter boxes, or flooring)
Personal price limit for the house including fittings: 350,000 + additional building costs
Preferred heating system: Air-to-water heat pump + wood stove
If you had to give up something, which features/extensions could you do without or not do without? Basically doesn’t matter as long as the reasoning is plausible
Why does the design look like it does now?
The basic design is from the Danwood website (House Park 181W), but there the staircase is in the middle of the living room and kitchen. Because we want an open staircase but a central stair takes up too much space, we moved the staircase and redesigned the upper floor accordingly. Previously, we had considered bungalow plans, but those were discarded due to floor space ratio and plot shape.
- General opinions welcome
- Do you see potential improvements in the layout?
- What do you think about the open design (hallway, staircase, living-kitchen area)?
- What do you think about the south-facing windows? I’m concerned the house might overheat in summer with so many windows.
Thanks in advance for your opinions!
Isometric interior view of a house: living room with sofa, dining table, kitchen, staircase, storage room.
Isometric floor plan of a house: bedroom, walk-in closet, staircase, living room.
Modern single-family home with green garden, playground, fire pit, and garden shed.
Modern two-story house with garage, driveway, garden, trees, and fire pit.
Site plan with parcels, floor plan lines, and plot boundaries.
Floor plan of a house with staircase, bedroom, kitchen, bathroom, living room and dining table.
Floor plan of a house: open living area with sofa, dining table, kitchen, staircase, and bedroom.
Technical floor plan: large dark rectangle with smaller light gray rectangle and dimension lines in mm.
4 May 2019 14:21
Do you also have neutral floor plans (2D)? Visualizations are not very helpful without plans. Thank you. Preferably with dimensions and the house on the plot.
Ben-man
4 May 2019 17:26
Thank you for your reply! I have attached the pictures to the first post.
Something I just realized: Is it actually allowed to build the garage like this, or does the east side of the garage have to be built exactly on the property line?
E
Escroda
4 May 2019 17:55
Ben-man schrieb:
Is it actually allowed to build the garage like this?
No. In the state of Hesse, designated buildings may be constructed either directly on the property boundary or with a minimum distance of 1 meter (3.3 feet) from it.
Niloa
4 May 2019 18:30
Ben-man schrieb:
An open staircase (even though it’s not the best solution in terms of energy efficiency)
What do you mean by that? Are you worried about drafts? In modern houses, there are no temperature fluctuations; it’s equally warm everywhere.
Ben-man
4 May 2019 18:35
Escroda schrieb:
No. In Hesse, privileged buildings may be constructed either directly on the boundary or with at least a 1m (3.3 ft) distance from it.
That was clear. Would the garage be allowed to be built as shown in the attached picture in this post? It doesn’t look very nice, it’s just for my better understanding.
Niloa schrieb:
What do you mean exactly? Are you worried about drafts? In modern houses, there are no temperature fluctuations, it’s equally warm everywhere.
Not that, but in the end, the upper floor will also be heated even if nobody is using it.
