ᐅ New Construction Upper Floor Bathroom Layout – Feedback?
Created on: 20 Mar 2018 11:52
Sammydog
We have nearly completed the design of our town villa. However, I am still unsure about the layout of the bathroom on the upper floor. Because of the ventilation pipe from the toilet flush, a wall cladding will be necessary, which I find less than ideal. What do you think would be the best way to handle this? I would appreciate any tips and suggestions, and am also open to alternative floor plan options.
2D-Badgrundriss mit Badewanne, Toilette und Waschbecken
2D Badgrundriss mit Badewanne, Wäscheschacht und Maßangaben
3D-Render eines Badezimmers mit Badewanne, Waschbecken und Fenster
Sammydog
6 Apr 2018 20:15
I worked a bit more on a T-shaped wall.
3D bathroom with sink, bathtub on the left, and toilet on the right, floor plan below
6 Apr 2018 21:54
Sammydog schrieb:
I tinkered with a T-wall again.
Why? Because T-walls are currently popular?
Edit: This isn’t a separate apartment, is it?
Please don’t get sidetracked and stay on topic.
Otherwise: zigzagging just to create a perspective you never see again (except on a floor plan from above) has no advantages. There’s really no order or logic to it.
11ant7 Apr 2018 21:08
Sammydog schrieb:
I worked a bit more on a T-junction wall.
When it comes to screws, there is a saying: "tighten until firm, then stop," meaning you shouldn’t over-tighten. Homeowners who think they’ve finished should be restrained like Troubadix.
Sammydog
18 Apr 2018 16:30
I would like to place the bathtub under the window.
Bathroom floor plan with bathtub, double washbasin, and toilet in the layout
Sammydog
18 Apr 2018 16:32
I am still considering how to build in the bathtub at a window sill height of 80 cm (31.5 inches) so that you have an unobstructed view outside while bathing.
Simple interior sketch with window front, door on the left, and base under the window.
Sammydog
18 Apr 2018 16:33
I think placing a platform under the bathtub already brings it to the right height. However, when lying inside, you look at the window frame. So, is this really only possible with floor-to-ceiling windows?
