ᐅ Why does the Malm bed wobble despite proper assembly?
Created on: 19 Dec 2021 08:37
Tireyhan
Tireyhan
19 Dec 2021 08:37
I recently assembled an IKEA Malm bed, and despite very careful assembly, the bed still wobbles slightly when leaning on it. I tightened all the screws and followed the assembly instructions precisely, yet there remains some play in the structure.
I am particularly interested in which structural or material factors can cause wobbling in a Malm bed despite proper assembly. Are there common weak points in the design that lead to joint play? Or could it be related to the condition of the flooring or uneven load distribution?
Another consideration is whether the wood or particleboard used, even with correct assembly, might slightly flex over time and thereby increase the wobbling.
I look forward to your feedback and any technical explanations regarding possible causes of this issue. Thank you!
FEKAU
19 Dec 2021 10:12
Hello Tireyhan,
Wobbling in a Malm bed can have several causes despite correct assembly, which should be checked systematically:
1. Screws and connectors: Even when tightened firmly, connections made from particleboard material can give slightly. It is recommended to check all screws again after a few days and tighten them if necessary.
2. Uneven floor: An uneven surface can cause rocking movements that appear as wobbling. A spirit level can help to rule this out.
3. Bed frame construction: The Malm bed is primarily made from particleboard and is not designed for very high loads or large play. Constructive tolerances are common here.
4. Accessories and slatted frame: Check if the slatted frame is installed correctly and not too loose. An ill-fitting or damaged frame can lead to instability.
5. Material deformation: Engineered wood products react to humidity and temperature, which can cause minimal warping.
Recommendation: Recheck the screws after several days, use possible pads (such as felt gliders) under the bed legs to compensate for unevenness, and review the usage conditions.
Best regards.
Linavin
19 Dec 2021 11:04
FEKAU schrieb:
The Malm bed is primarily made of particleboard and is not designed for very high loads or generous tolerances.
This statement is interesting but leaves unclear what exactly is meant by "very high loads."
How do you measure an appropriate load before a bed starts to wobble? Is the wobbling actually caused by the load, or is it more an unavoidable characteristic of the material and construction?
Also: Can a supposedly good assembly completely eliminate the slight flexibility in the components that is inherent due to manufacturing?
I believe more detailed analyses of material behavior and joint tolerances are still needed. Are there any manufacturer specifications regarding maximum torsional or tilting loads for the bed? Or general technical parameters we should consider?
Laukau5
19 Dec 2021 13:48
I would like to take a closer look at this topic by examining the construction method of the Malm bed.
The bed is primarily made from medium-density fiberboard (MDF) and particleboard, materials that have some flexibility and are sensitive to point loads as well as moisture exposure. The connecting elements usually consist of wood screws, dowels, and metal fittings, which wedge into these materials but do not allow for completely stable, rigid connections.
Let’s consider the overall structure:
1. Side panels and head/foot boards: They carry most of the load and are connected by broad surface joints that allow minimal movement under pressure and tension.
2. Center support and slatted frame: In Malm beds without an additional center rail, slatted frames tend to rock or wobble even under light loads, which directly affects the entire bed frame.
3. Screw connections: Initially tight, they can loosen slightly over time due to material fatigue or minor stresses in the wood-based material.
Different loading scenarios (such as leaning sideways or dynamic movement) can cause the bed system to wobble slightly, even when assembled correctly.
It would be helpful to know if your bed has a center support beam and how the slatted frame is installed. From my experience, retightening the screws after about a week and, if necessary, adding extra corner brackets can significantly improve stability.
Additionally, a flat and level base is essential for a stable construction. Even a small gap during assembly or between the bed and floor can cause resonance, leading to noticeable wobbling.
Could you indicate whether you have already retightened the screws and describe the type of floor surface you have?
Tireyhan
20 Dec 2021 07:22
Laukau5 schrieb:
Could you please specify whether you have already carried out any follow-up tightening and how your floor is constructed?
Thank you for the detailed insight. I checked and retightened the screws after about 3 days, but that only resulted in a very slight improvement. The floor is laminate and completely level according to a spirit level, so I can rule out any unevenness. The bed also stands on felt pads to prevent scratches, which adds some cushioning at the contact points.
The slatted frame is the standard IKEA model without a central support beam. It fits quite tightly in the construction but is made from wooden slats and is relatively light.
Maybe the missing central part is responsible for some flexibility? Or is it normal that, despite proper assembly, there is minimal play causing some wobbling?
I have started considering whether an additional central beam might help—possibly even reinforcing it with angle brackets.
What are your experiences with this?
FEKAU
20 Dec 2021 10:33
Tireyhan schrieb:
The slatted frame is the standard frame from IKEA without a center support beam.
This is a common cause of the problem. In beds, especially those with inserted slatted frames, the absence of a center support beam often leads to increased movement and thus wobbling.
The center support beam distributes the load more evenly across the side rails and prevents the slatted frame from sagging or shifting sideways. This directly affects the overall stability of the bed.
Here are the key points:
- Installing a center support beam is recommended by many users, as it improves load distribution and significantly reduces wobbling.
- Additionally, strong angle brackets at the joints of the side rails with the headboard and footboard help increase clamping forces within the frame construction.
- Also, check that the slatted frame fits securely into the designated holders without any play.
If the design with the standard frame does not include a center support beam, retrofitting a beam is a sensible measure to achieve the desired rigidity.
I hope these facts are helpful.
