ᐅ How can I prevent wobbling in Malm beds?
Created on: 13 Oct 2022 08:17
benmatteo
benmatteo
13 Oct 2022 08:17
Good morning everyone, I recently got a Malm bed from IKEA and noticed that it wobbles a bit when I move or sit on it. This is obviously frustrating, as I want it to be as stable as possible. So my question is: How can I specifically prevent wobbling with Malm beds? What steps or measures are recommended to ensure long-term stability? Are there any known weak points in these beds that I should watch out for? I look forward to your experiences and advice.
bapar
13 Oct 2022 08:45
Hello benmatteo, your question is very relevant, as the Malm bed can indeed be critical in terms of stability if certain details are overlooked. First, it is important to know that the Malm bed is often supported by a central support rail, which is connected to the headboard and footboard. A common mistake is that the screws there are not tightened enough or become loose after some time. I recommend the following steps:
1. Tighten all screws, especially those on the central support rail, using a hex key – be careful not to overtighten to avoid damaging the wood.
2. Check if the slats that hold the bed base are properly seated and have no gaps.
3. If your bed was delivered without a central support rail, this can cause particularly wobbly behavior; in this case, a modification or additional reinforcement with support blocks is worthwhile.
Small plastic or felt pads under the feet can also improve stability if the floor is uneven. Did you assemble the bed entirely by yourself, or did you have assistance?
benmatteo
13 Oct 2022 09:12
bapar schrieb:
A common mistake is that the screws are not tightened enough there or they loosen over time.
Thanks, that makes sense – I checked the center beam and it seems the screws might not be very tight.
bapar schrieb:
If your bed was delivered without a center beam, it can cause especially wobbly behavior
Mine has a center beam, properly positioned in the middle. However, the wood sometimes sounds a bit hollow when I tap it. Could that affect the stability? And what do you think about reinforcements with metal angle brackets at the corners? Would that help or is it rather uncommon?
Blavin
13 Oct 2022 09:37
Regarding stability in Malm beds, the main issue is often the connection between the headboard and footboard with the central rail. Screws can loosen over time with use, causing wobbling.
Concerning the hollow sound when tapping on the wood: this usually indicates thin plywood panels, which do not necessarily compromise the structure as long as the joints are properly made.
Metal brackets can be helpful but need careful planning to avoid introducing stress into the wood. Targeted reinforcements are recommended only at identified weak points. Alternatively, wooden battens can be additionally screwed into the corners, which places less stress on the furniture.
JAMESONB41
13 Oct 2022 10:02
Retighten screws, check the central beam. Angle reinforcements add stability. Felt pads for uneven floors. Usually, that’s all you need.
benmatteo
13 Oct 2022 10:45
Blavin schrieb:
Metal brackets can be helpful but need to be carefully planned, as they can otherwise introduce stress into the wood.
Thank you for the advice. I would prefer not to damage the furniture. Do you think wooden strips would be a safer option in that case?
My floor is actually slightly uneven. I will try that, thanks for the suggestion.
