ᐅ How can Malm beds be stabilized permanently?
Created on: 8 Oct 2018 19:23
Husseinpra
Husseinpra
8 Oct 2018 19:23
I recently bought a Malm bed from IKEA, but I’ve noticed that after some time it starts to wobble and overall doesn’t feel as stable as it did right after assembly. I’m interested in learning how to make Malm beds more stable over the long term so they remain sturdy under heavier loads and don’t produce any noise or movement.
In particular, I’m curious if there are additional reinforcements available, whether special screws or fasteners are better suited, or if the bed should be assembled differently.
It would also be helpful to know if it’s worth installing special wood or metal reinforcements, and what experiences you’ve had with that.
Thanks in advance for any tips!
bijo54
8 Oct 2018 20:05
it is best to tighten the screws at the bottom of the bed frame; this often resolves most issues.
Additionally, you can install corner braces from the hardware store at the corners, which increases stability with little effort.
korosu
8 Oct 2018 20:47
For stabilization, I recommend installing a central beam or, if available, securing the existing central support beam.
Often, platform beds wobble because the support points for the slatted bed bases are not stable enough.
Louie
8 Oct 2018 22:12
Hello Husseinpra,
I understand your concern well, as a stable sleeping surface is really important for a good night’s rest. The Malm bed looks nice, but it can sometimes become a bit wobbly with prolonged use.
To permanently stabilize your bed, you can try the following:
1. Regularly check and tighten screws and connectors, especially in wooden joints, as they tend to loosen with use.
2. As already suggested, adding a central support beam can help distribute the weight better and reduce stress on the sides.
3. Install wooden strips or metal brackets at the joints to prevent the frame from twisting.
4. Using a slatted frame with sturdier support points can also improve overall stability.
I personally added two metal brackets to my bed frame, and that really helped eliminate the wobbling completely.
If you want, I can provide more details.
Husseinpra
9 Oct 2018 06:39
bijo54 schrieb:
Install angle brackets from the hardware store at the corners; this increases stability without much effort.
Thanks, that sounds good! Do you mean simple metal brackets usually used for shelving?
And what is the best way to attach them without damaging the bed? I also want to avoid affecting the appearance.
JAFUHAU
9 Oct 2018 11:53
I can definitely understand how annoying a wobbly bed can be – I’ve experienced it myself, and it really affects how well you rest.
As someone not very skilled in DIY, I was initially afraid that fixing the bed might cause even more damage. But then I installed simple metal brackets inside the corners underneath the bed frame, where they are barely visible. That worked wonders.
Louie schrieb:
Install wooden slats or metal brackets at the joints to prevent the frame from twisting.
That’s exactly how I do it as well.
Does anyone have experience with how to do this without the bed squeaking when you move? That’s my next problem after stabilizing it...
