ᐅ How can Malm beds be stabilized permanently?
Created on: 8 Oct 2018 19:23
Husseinpra
I recently bought a Malm bed from IKEA, but I’ve noticed that after some time it starts to wobble and overall doesn’t feel as stable as it did right after assembly. I’m interested in learning how to make Malm beds more stable over the long term so they remain sturdy under heavier loads and don’t produce any noise or movement.
In particular, I’m curious if there are additional reinforcements available, whether special screws or fasteners are better suited, or if the bed should be assembled differently.
It would also be helpful to know if it’s worth installing special wood or metal reinforcements, and what experiences you’ve had with that.
Thanks in advance for any tips!
elgla
9 Oct 2018 12:27
I am very familiar with the problem of squeaky beds, and it can be quite frustrating.
Sometimes, treating the wooden joints and contact surfaces with some wax or a special furniture polish helps to reduce friction and thus the noise.
At the same time, you should avoid tightening the screws too much, as over-tightening can also cause squeaking sounds.
JAFUHAU schrieb:
Has anyone got experience on how to do this best without the bed squeaking when you move?
You should keep that in mind with any reinforcements.
Eugeneki
9 Oct 2018 15:14
To ensure long-term stability, both mechanical reinforcements and material quality are important. Malm beds are made from particle boards, which tend to warp under load.
An additional center beam made of solid wood or metal, installed beneath the slatted frame support, distributes forces more evenly and prevents twisting. This beam should be secured with sturdy metal brackets or support legs.
Furthermore, I recommend improving the quality of the assembly materials during installation—for example, using stronger screws and washers—since the screws provided by IKEA are sometimes not optimal.
Husseinpra
9 Oct 2018 16:48
Eugeneki schrieb:
An additional central beam made of solid wood or metal, installed beneath the slatted bed base, distributes forces more effectively and prevents twisting.
Thanks for the tip! Is there any experience on which beam is more suitable – wood or metal?
And do you need any special tools for the installation? I only have a cordless drill, hammer, and a few screwdrivers.
MANUEL
10 Oct 2018 07:11
Metal beams are stronger and more durable than wood but are more difficult to assemble.
If you only have basic tools, I recommend solid wood battens. These can be easily fixed using brackets and screws.
Husseinpra
10 Oct 2018 09:37
MANUEL schrieb:
If you only have basic tools, I recommend solid wood battens. You can easily fix them with brackets and screws.
Perfect, thanks. I will proceed like that.
One more question: How important is it to regularly check and tighten the screws? Is that essential for maintaining stability, or is a proper initial installation sufficient?
U
umberto
10 Oct 2018 10:26
Retightening screws is very important because wood joints can loosen over time.
It is not enough to assemble carefully just once. An inspection after a few weeks and then regularly should be scheduled.
