ᐅ How can I securely fasten Malm furniture to a wooden floor?
Created on: 15 Oct 2023 14:07
Monroelo63
Hello everyone, I have a fairly specific question: I would like to securely and stably fix my Ikea Malm furniture to a wooden floor, as otherwise it feels a bit wobbly to me. What options are there to secure the furniture without damaging the floor so that it won’t slip or tip over? I’m thinking of practical methods that provide stability but are reversible in case I want to move the furniture later. Maybe someone has tips on choosing fastening materials or preparing the floor or the furniture? I would be very grateful for any advice on suitable materials or steps!
Monroelo6316 Oct 2023 10:17Thanks in advance for the suggestions! The combination of felt glides and rubber pads sounds especially interesting. How exactly do you attach them? Do they simply stick on, or do you need to use screws? And how durable are the pads if you plan to move the furniture around frequently? I want to avoid damaging the floor but also don’t want too much hassle. At what thickness of rubber pads would you recommend for them to be stable enough?
The pads are usually glued on. It is important to thoroughly clean the floor and the underside of the furniture beforehand to ensure proper adhesion of the glue. For Malm furniture, rubber pads with a thickness of at least 3-5 mm (0.1-0.2 inches) are recommended to noticeably improve stability. This solution is reversible and still protects the floor.
Monroelo63 schrieb:
How exactly are these attached? Do they just stick on, or do you need to use screws? Most anti-slip pads are glued on. Screws should be used with extreme caution on wood flooring with Malm furniture, as they can damage the floor.
Monroelo63 schrieb:
And how durable are the pads if you want to move the furniture around frequently? High-quality pads usually withstand several furniture moves; please follow the manufacturer’s instructions and keep the surface clean.
A combination of felt glides and rubber pads is a good compromise between durability and floor protection.
I also had some slight concerns that the furniture might slip, so I chose furniture fasteners with Velcro. They are very practical because you can securely attach the furniture while still being able to remove it at any time. However, you should check whether the Velcro leaves any residue on the wood. My experience so far: it works great, especially with light or medium-sized furniture.
I really like how many solutions have been shared here! 🙂 Especially the small uncertainties regarding floor and furniture protection helped clear up a lot of my thoughts. The combined use of rubber pads, felt gliders, and possibly hook-and-loop fasteners seems like a practical approach that is both flexible and gentle on the floor. If you’re unsure, I would recommend testing a small area first – that way you can see if it really has no effect on your wooden floor and if you feel confident with it. Good luck!
