ᐅ Are there any recommendations for Malm furniture for beginners?
Created on: 7 Dec 2022 08:17
piarvid
piarvid
7 Dec 2022 08:17
Are there any recommendations for Malm furniture for beginners who have no prior experience with assembly, especially regarding which tools are needed, which assembly steps are critical, and how to avoid common mistakes? I am considering putting together a dresser or a bed from the series and want to make sure I don’t encounter unexpected difficulties during assembly. Maybe you could also provide tips on the included materials or how to best use the instruction manual.
edisondan
7 Dec 2022 08:42
When assembling Malm furniture, especially for beginners, it is advisable to read the entire instruction manual beforehand and have the necessary tools ready. For most parts, a Phillips screwdriver is sufficient, ideally a cordless drill with adjustable torque settings to avoid overtightening screws. The joints between the side panels and the back panels are often critical, as precise alignment is important here. Before starting assembly, check all individual parts for completeness and avoid overtightening the screws to prevent damage to the materials.
Paunon
7 Dec 2022 09:03
Tools: Phillips screwdriver plus cordless drill with torque control. Follow the instructions step by step without shortcuts. Sort the parts before you begin.
NUPIN
7 Dec 2022 09:42
Great choice picking Malm furniture for your first project! It’s perfect for beginners 🙂 I built a Malm bed last year, and it was really fun! Just stay calm and take your time assembling each piece carefully. If something goes wrong, no worries—I’ll definitely help you sort it out 100%! Good luck!
PAREL
7 Dec 2022 10:11
A structured assembly guide for Malm furniture:
1. Carefully check and sort all components
2. Study the instructions thoroughly, paying special attention to the sequence of assembly steps
3. Prepare the necessary tools (screwdriver, possibly a hammer for dowels)
4. Tighten connections with dowels and screws only by hand at first; fully tighten them only at the end
5. Check the fit of all parts during assembly; avoid forcing individual pieces together
Common mistakes include tightening all screws too early and inaccuracies when positioning back panels. Stay patient and work step by step to reliably avoid mistakes.
Ethan
7 Dec 2022 11:06
Beginners should pay special attention to the following basics: Storage furniture like Malm is designed for self-assembly, but precise work and careful handling of materials are essential. Take plenty of time during assembly, work on a flat, clean surface, and use the instructions as a "construction plan." If you are unsure about certain steps, mark the parts with small sticky notes or numbers. Many beginners underestimate the importance of tightening screws gently to avoid damaging the materials. For back panels, it is helpful not to tighten the screws too much, as these are usually made of thin material.
