ᐅ Is it possible to use Malm beds with different types of slatted bed bases?
Created on: 2 Mar 2016 08:23
Fubilal61
I have a rather specific question that I couldn’t fully answer even after thorough research in any store or on IKEA’s website:
Is it possible to easily combine Malm beds (specifically the IKEA model with the common metal frame and distinctive design) with slatted bed bases that are NOT from IKEA? More precisely, I’m interested in whether the slatted bed bases usually supplied by IKEA can be replaced by other models without compromising the bed’s stability or comfort, or causing any damage.
I’m considering switching to an adjustable slatted bed base but have concerns about the fit and potential stresses on the frame.
Does anyone have practical experience or solid knowledge about this? Thanks in advance for your insights!
Briefly and concisely from my experience:
That is absolutely true!
I have been using my Malm frame for almost 2 years now combined with a widely available slatted base from another brand.
It is important that the frame is not damaged or bent and that the mattress rests properly.
What you should definitely do is measure the slatted base beforehand and check the support surfaces on the bed frame. Some slatted bases are slightly wider on the sides than the IKEA models, which can cause fit issues.
But the combination is definitely worthwhile.
susar schrieb:
The bed remains stable, and you can improve your sleeping comfort!
Additionally, I would like to point out an important detail:
The connection between the slatted bed base and the bed frame.
Not all slatted bases have the same hooking angles or support strips that keep them securely in place. Especially with adjustable slatted bases, there can be some movement or a lack of fasteners on the frame edges, which may cause the base to shift when lying down.
If the slatted base is not securely positioned, there is a risk of squeaking or even damage to the bed frame due to friction or increased pressure in certain areas.
My advice: If you do not want to use the original base, make sure to check whether the alternative slatted base sits firmly on the Malm frame – if necessary, use spacers or non-slip mats to improve stability.
matthewon4 Mar 2016 07:29Issac_kla2 schrieb:
You really can’t say that IKEA products are 'compatible' in any general senseI wouldn’t generalize it like that! Of course, IKEA beds are designed to work best with their original components, but I personally combined a Malm frame with a high-quality motorized slatted base from a specialty retailer. It fits perfectly, no issues, and I’m very pleased.
Brian schrieb:
Load capacity and stability: Malm beds are sturdy, but not heavy-dutySure, if someone has a very unstable frame, they should be careful; in my opinion, the Malm is robust enough, and the connecting hardware is solid.
So my conclusion: If you measure carefully and do some research, you can easily push the limits of “compatible” parts. If not, you will naturally encounter many problems.
Here’s a small tip from me to make the whole process stress-free with minimal effort:
Actually, the measurements and bed base heights are the most important things.
If you feel uncertain, ask the seller of the slatted bed base whether it is suitable for IKEA Malm beds or if there are any customer reviews available.
Sometimes there are auction or dealer offers that explicitly state "fits Malm." Then you can be sure it will work.
And honestly: I have sometimes just placed bed bases in without much checking. If you see that the base has no sharp edges and doesn’t wobble, it usually fits 🙂
Good luck with your project and of course, sleep well! 😊
Fubilal615 Mar 2016 09:00Thank you all for the detailed and helpful answers!
This made me realize how important precise measurements and attachment points are. It’s reassuring to hear that many of you have had good experiences when paying close attention to the details.
For my Malm bed, I will now measure an adjustable slatted base and compare its dimensions with my bed frame. The suggestion from dota57 about using anti-slip mats also sounds very sensible for securing it.
I hope I can put this combination together without causing any damage to the bed or making it unstable. Thanks again, this has really helped me a lot!
