ᐅ Why does my BILLY bookshelf squeak despite regular maintenance?
Created on: 29 Aug 2021 18:37
Yousef
Yousef
29 Aug 2021 18:37
I have a BILLY shelf that keeps squeaking even though I have maintained it regularly. To explain: I mean that the individual shelves or the joints between the side panels and shelves produce a slight but clearly audible squeak when under load. I have already tightened the screws several times, the shelf is standing on a level floor, and I have also tried using some silicone spray on the joints without lasting success. Therefore, I would like to understand why the shelf can still squeak and what further measures are effective against squeaking in such constructions. Could material fatigue or other causes be responsible that I might have overlooked? Thanks in advance for your insights.
BEMAU
29 Aug 2021 19:14
Hello Yousef,
Regarding your issue: squeaking in furniture like the BILLY bookshelf often occurs due to friction between wood or wood-based surfaces that shift or move slightly against each other. Even with regular maintenance, the squeaking may not completely disappear because microscopic movements can still happen under load.
The following points are commonly responsible:
1. Wood moisture: Fluctuations in air humidity cause swelling and shrinking in the wood material, which can create tension and friction.
2. Screws and joints: Loose or overly tightened screws can cause movable stresses.
3. Plastic or metal fittings: Material combinations between wood and fittings can also generate noise.
4. Uneven floors: Even if the floor appears level, slight unevenness is enough to cause movement.
I recommend checking all furniture joints again, loosening screws slightly if necessary, and then carefully applying wood glue at the contact points if slight movement between wood surfaces is noticeable. Additionally, graphite powder instead of silicone can help, as it is more durable and dry.
If the shelf is under load, you should also check whether the shelves fit exactly in the guide rails or if there is slight play. Even a small amount of play can lead to squeaking.
I hope this structured analysis is helpful to you.
enrique7
30 Aug 2021 07:53
BEMAU schrieb:
Squeaking in furniture like the BILLY bookcase often happens due to friction between wood or wood-based surfaces
That is basically true, but I think this explanation is a bit too simplistic. I often wonder whether the quality of the materials used and the manufacturing processes are also significant factors.
IKEA products often use MDF or particleboard, which are less stable under moisture and load compared to solid wood. This can cause micro-cracks or deformations that are barely visible at first but lead to moving parts over time.
I have also noticed that the connecting fittings in BILLY bookcases are often made of plastic, which slightly deforms with temperature changes. This might explain the persistent tensions that develop.
Yousef schrieb:
Could material fatigue or other causes be factors I haven’t considered?
Yes, material fatigue in particleboard is indeed an important issue here. That’s why I would recommend checking carefully for such cracks or warped areas in the bookcase.
Has anyone had experience with long-term solutions for this type of material fatigue? Or are these noises typical and unavoidable for BILLY bookcases?
TEOZAR
31 Aug 2021 10:22
Hello Yousef,
I would like to take a step back and consider the basic construction principle of BILLY shelves. The shelf uses combined mechanical fastenings (e.g., dowels plus screws) and is made from wood-based panels, which are generally susceptible to moisture changes.
enrique7 schrieb:
Material fatigue in particleboard is a key issue here.
I agree and would add that the combination of several small individual components with different stresses at the joints can cause the noise. Additionally, the play between the shelves and the side supports also plays an important role.
I recommend placing the shelf in a quiet area, applying some weight, and carefully observing and listening to where the squeaking occurs. Then make targeted small adjustments:
- Loosen and gently retighten screws
- Use thin felt or foam strips between shelves and carcass as cushioning
- Replace plastic fittings with metal versions if possible
Also keep in mind: when you move or reassemble the shelf, small dirt particles in the joints can cause squeaking. Cleaning often helps here.
I hope this helps you move forward with your issue.
