ᐅ Why do some connectors come loose in BILLY shelving units?
Created on: 18 Sep 2017 08:23
ParkerstinP
Parkerstin18 Sep 2017 08:23I have a question that has been on my mind for a while: Why do the connectors in some Billy bookcases seem to come loose over time, especially the dowels and screws that hold the shelves and side panels together? I have noticed that even with proper assembly and normal use, the stability of some shelves decreases because the fasteners loosen or even partially fall out. Is this due to the quality of the materials, poor installation, or could there be mechanical or physical reasons, such as fluctuations in humidity or weight load?
The issue of loosening connectors in BILLY shelves is well known and can usually be attributed to several factors. One reason is the wood fiber structure of the panel boards, which expand and contract with changes in humidity. This causes dowels and screws to become loose. Additionally, the quality of assembly and proper tightening of screws play an important role. Over-tightening or uneven tightening can damage the material, while under-tightening leaves the connection unstable. Excessive load on the shelves also puts increased strain on the joints. Overall, the interaction between material properties and assembly is crucial.
A structured approach is helpful here: First, you should follow the assembly instructions exactly—especially when screwing in screws and inserting the dowels. Over-tightening can cause stripping, which weakens the material.
Second, it is recommended to lightly coat the dowels with wood glue before assembling to prevent slipping. Also, regularly retightening the connection screws after some time significantly increases stability.
Third, the shelf should always stand vertically and not be subjected to rocking motions, as dynamic loads can loosen the connections.
Finally, in conditions of increased humidity or temperature fluctuations, controlled room ventilation is advisable to minimize the shrinking and swelling of the wood-based materials.
Rashadmeo18 Sep 2017 12:36Oh, I know that! I had the exact same problem with my old BILLY bookshelf – the connectors loosened over time, and the shelf started to wobble! 🙁 But with a little patience and properly tightening the screws, it quickly went away! 🙂 My recommendation: just regularly check the connection parts, and you’ll enjoy it for a long time! And don’t be afraid of small maintenance tasks – they’re just part of it! 😀
To explain the causes in more detail: The BILLY shelf unit is made from particleboard, which naturally reacts sensitively to moisture. Fluctuating humidity causes the material to expand or contract slightly, which can stress the joints. Over time, this can cause dowels and screws to loosen. It is important to understand that this is not a material defect but an inherent characteristic of wood-based panels.
Furthermore, the load on the shelves can be a critical factor: Excessive weight leads to greater deformation and thus increased strain on the connectors.
For assembly, I strongly recommend:
- Using precisely fitting dowels
- Avoiding overtightening screws
- Occasionally retightening screws
This will significantly extend the lifespan.
If anyone has further questions, I am happy to answer them.
