ᐅ Why do some Billy bookshelf shelves warp despite proper installation?
Created on: 23 Jun 2018 09:14
Tunahan57
Tunahan57
23 Jun 2018 09:14
I have a question that has been on my mind for a while, and so far I haven’t found a really satisfying explanation: Why do some Billy bookshelf shelves warp even when assembled correctly?
I have built several shelves, carefully following all assembly instructions. Still, after some time, especially with longer shelves, warping and bending occur, which I initially thought was unusual if the assembly was done properly.
I wonder if environmental factors like humidity or temperature fluctuations play a bigger role, or if it could be due to the material quality or the way the shelves are constructed.
Are there perhaps other, less obvious reasons why these deformations happen even when everything seems to be done right? I look forward to your opinions and experiences!
danial60
23 Jun 2018 10:37
Tunahan57 schrieb:
Why do some Billy shelves warp despite correct installation?
First of all, it’s important to understand that the material itself plays a major role. Billy shelves are usually made of particle board or MDF, which is a composite material highly sensitive to moisture and temperature changes. Even if everything is installed properly, fluctuations in humidity can cause the shelves to expand or contract, which explains the warping.
Additionally, the load on the shelves is a significant factor. If they are overloaded or the weight is unevenly distributed, it can lead to sagging that over time appears as warping. The support points are also important: if the shelves are not fully supported, unwanted stress concentrations can occur.
Another issue is the installation itself: sometimes everything looks correct, but if the screws or dowels are not tightened enough or if the shelf is placed against a wall that is not perfectly level, tensions can develop that cause the material to warp.
I would therefore ask: what are the room conditions (humidity, temperature), how heavily are the shelves loaded, and are the shelves continuously supported? A description of your installation and usage would be helpful so I can address possible causes more specifically.
Johnnybe
23 Jun 2018 11:05
I would bet on material quality and load capacity. Billy is not designed to hold too much weight. Also, the shelves should not be placed in damp rooms or exposed to high humidity.
Far34
23 Jun 2018 12:17
If the installation was done properly, the problem often lies in the load. Overly heavy objects placed on only a few support points cause sagging and thus warping. Adding a second support point often helps.
O
ottilie
23 Jun 2018 17:42
Johnnybe schrieb:
Billy is not designed for heavy loads.
I would like to challenge that statement! I have seen shelves that did not warp at all despite being subjected to significant loads.
Perhaps the issue is not always the material quality, which is often blamed, but rather the manufacturing process, where the panels were either not properly pressed or bonded with low-quality adhesive. Or quite simply: it could be due to production defects, where the material already has internal stresses that eventually “release” and cause warping.
We should stop constantly blaming installation errors or environmental factors. Maybe the cause of this phenomenon is a production flaw that does not receive enough attention.
GU-LAU60
24 Jun 2018 08:22
I believe it is important to consider storage when dealing with warping. If the shelving was stored for a long time in a damp condition before installation, the panels will swell and warp later. Installing it immediately after improper storage does little to prevent this.
