ᐅ How can I protect IKEA Billy bookcases from warping due to temperature changes?
Created on: 17 Aug 2020 08:34
TokenHello everyone,
I am currently dealing with the issue of how to better protect my Billy shelves from warping caused by temperature fluctuations. Especially with extreme differences in room temperature or strong sunlight exposure, the shelves tend to bend slightly in the middle, causing them to sag or weaken over time.
I have considered repositioning the shelf entirely, but I would like to know if there are other, more effective measures to ensure stability despite frequent temperature changes. Perhaps some of you have experience with protective measures such as additional reinforcement, special materials, or tricks to reduce the load.
It is important to me that the solution is practical and not too expensive, as I would like to keep the shelf as close to its original condition as possible.
Thank you in advance for your tips and advice!
Hello Token,
I am very familiar with the issue of Billy shelves reacting to temperature changes. The wood, or in the case of Billy shelves especially the chipboard with melamine coating, expands and contracts due to fluctuations in temperature and humidity. This can become particularly noticeable when exposed to sunlight or when the indoor climate varies significantly.
A first important step is to always secure the shelf level and firmly to the wall. This at least prevents tipping and significant bending.
Additionally, it’s worth reinforcing the shelves with extra support strips. You can attach wooden battens or metal brackets to the underside of the shelves to better distribute the load.
It also helps to distribute the weight evenly and avoid placing too much load on individual shelves.
Due to temperature effects, you can also try to keep the shelf away from direct sunlight or heating vents. Maintaining a constant humidity level, ideally around 40-60%, also reduces the wood’s swelling and shrinking.
If you like, I can also send you links to installation aids and reinforcements that I have personally used.
Token schrieb:
that they give way or sag slightly over time
Hello Token,
I’d like to emphasize again that temperature changes are mainly related to humidity levels. If you have a warm and humid environment during the day and a cold, dry climate at night, the wood will swell when warm and shrink as it cools and dries out.
That is absolutely correct – proper climate control in the room makes a significant difference.
Additionally, I would recommend securing the shelves more flexibly rather than completely rigidly, so they can expand without warping the structure. For example, using bolt-and-nut combinations on the sides that allow some movement while still providing stability, or washers that maintain a small gap.
Avoiding excessive loads, as Tommy already mentioned, is essential. It’s better to install more shelves and place less weight on each shelf.
Tommy38 schrieb:
Due to temperature effects, you can also try to keep the shelf away from direct sunlight or heating air
I would additionally secure the floors with a thin plywood sheet underneath. This strengthens the load-bearing capacity and distributes the weight.
Screw the shelves to the wall and try to keep the temperature at the location as stable as possible; otherwise, wood will warp quickly.
Hello Token,
I can fully understand the issue, especially with low-cost particle boards like those used in Billy furniture, where temperature and humidity fluctuations often cause warping.
A practical solution I use myself: hardware stores sell metal angle brackets that can be screwed underneath the shelves. This provides significantly better stability and greatly reduces sagging.
Shelves made of solid wood or with edge banding reinforcement are also more stable, but this is a more costly option.
In my experience, maintaining consistent temperature by airing the room and avoiding dry heating air has proven effective, as strong fluctuations affect the boards.
For mounting, I always use the supplied wall brackets including anchors, which already prevents a lot of movement in the shelving unit itself.
