ᐅ BILLY Bookcase Alternative Shelves – Which Material?
Created on: 11 Aug 2020 14:07
Bo-be66
I have a Billy bookshelf from IKEA and would like to try an alternative material for the shelves instead of the usual particleboard. Currently, the shelves are typically made of coated particleboard with a thin melamine layer, which works well for many purposes, but I am interested in more durable, possibly sturdier, or visually more appealing materials.
I would appreciate any experiences and recommendations regarding suitable replacement materials for the BILLY shelves. The material should be relatively easy to work with (cutting, etc.), remain stable, and not add too much thickness, so the bookshelf does not look too bulky.
Have you ever used solid wood, plywood, MDF, or other materials for shelves? How durable are they, what about their appearance, and do you have any practical tips for selecting or working with them?
I look forward to your opinions and advice!
relupa
11 Aug 2020 16:22
I replaced the shelves of my Billy bookcase with oak wood. It was quite labor-intensive to work with, but the look is stunning. However, I can understand if the effort seems too much for you.
It might help to know that solid wood is somewhat sensitive to temperature and humidity changes. I have the shelf in the living room, where this is manageable.
For the hobby room, I would probably recommend plywood instead.
Fitigu
11 Aug 2020 16:49
From a technical perspective, plywood offers the best compromise between weight, stability, and workability for shelves in IKEA BILLY units.
Particleboard consists of compressed wood chips and resin with a melamine coating for protection. It is usually thinner and lighter but tends to sag more under load.
Plywood panels are made of several glued veneer layers of different wood species, which makes them significantly more dimensionally stable.
MDF is a homogeneous wood fiber product that paints well, but compared to other materials, it is heavier and less resistant to bending forces.
Solid wood has a high-quality appearance but is associated with greater thermal expansion and moisture sensitivity.
The choice should depend on the intended use, budget, and desired appearance.
theo63
11 Aug 2020 17:12
It is important to consider the expected loads on the floors and the spans that need to be covered.
Fitigu schrieb:
Plywood is the best compromise between weight, stability, and workability
That is generally true, but the exact quality of the plywood matters. Cheap softwood panels are less load-bearing than high-quality plywood made from birch veneer.
Additionally, the shelves have a height limitation. How certain are you that the new floor thickness will fit exactly? There are tricks to address this, or you can adjust the sides at the bottom of the shelf.
When it comes to moisture, it is important to differentiate between short-term exposure and long-term load. Prolonged excess moisture can even damage plywood.
Bo-be66
11 Aug 2020 17:53
theo63 schrieb:
It is interesting to consider the loads expected on the shelves and the spans that need to be covered.
Thanks for the input! The load will generally be moderate – books, some devices, mostly not excessive weight, rather evenly distributed.
The span corresponds to the internal dimensions of the BILLY shelf, so about 80–90 cm (31–35 inches), depending on the model.
theo63 schrieb:
How certain is it that the new shelf thickness will fit exactly?
That’s exactly my concern – I don’t want to use boards that are too thick. 12–15 mm (0.5–0.6 inches) seems appropriate to me. However, most alternatives I find are usually 18 mm (0.7 inches), which feels too bulky.
Are there any experiences with thinner plywood shelves at 12 mm (0.5 inches) or even thinner? Or alternatives that remain very thin yet stable?
flo-Theres
11 Aug 2020 18:28
Yes, 12 mm (0.5 inches) plywood usually works well as long as you don’t overload it. The strength is sufficient for the shelf spans of a BILLY bookcase.
Additionally, you can reinforce the shelves with brackets or supports if the load is higher.
An alternative is coated OSB boards, which are as sturdy as plywood and often cheaper but have a rougher appearance. They are thinner than particleboard and still strong.
However, keep in mind that OSB’s look is a matter of personal taste and it often needs additional finishing if you want a smoother surface.
Takutau
12 Aug 2020 08:55
Hello Bo-be66,
I have already tried different materials for my BILLY shelves and am happy to share my experiences:
Plywood in 12-15 mm (about 0.5-0.6 inches) thickness is a great alternative, easy to work with, and sturdy enough for everyday items and books. It is important to seal the edges properly, as this significantly extends the lifespan.
Solid wood looks really nice, but you should make sure that the wood is well dried, otherwise it can warp. For hobby rooms, I recommend plywood or even coated MDF panels, as these offer better protection against moisture.
One more tip: consider reinforcing the shelves with metal brackets or thin boards underneath if you plan to store heavy items.
Good luck with your project!
