ᐅ Why do some Billy bookshelf shelves warp despite proper installation?
Created on: 23 Jun 2018 09:14
Tunahan57
I have a question that has been on my mind for a while, and so far I haven’t found a really satisfying explanation: Why do some Billy bookshelf shelves warp even when assembled correctly?
I have built several shelves, carefully following all assembly instructions. Still, after some time, especially with longer shelves, warping and bending occur, which I initially thought was unusual if the assembly was done properly.
I wonder if environmental factors like humidity or temperature fluctuations play a bigger role, or if it could be due to the material quality or the way the shelves are constructed.
Are there perhaps other, less obvious reasons why these deformations happen even when everything seems to be done right? I look forward to your opinions and experiences!
Natan
24 Jun 2018 09:58
danial60 schrieb:
Material itself plays a major role
That is an important point. At the same time, I would ask: isn’t there a risk of confusing aesthetic distortions with structural defects here?
Is it possible that some users attribute warping to internal material stresses caused either by moisture or load, without clarifying the exact loading and usage context?
I also see a misconception in considering production and installation separately. Production-related stresses can certainly only become apparent after installation. Without historical context of the installation process and precise indoor climate data, a general answer is hardly possible.
My advice: Warping is a multifactorial issue, where all factors play a role – material, production, storage, installation, and use. Therefore, multiple aspects must always be considered together and not in isolation.
praWarre69
24 Jun 2018 14:03
ottilie schrieb:
Maybe the phenomenon is due to a manufacturing defect that doesn’t get enough attention.
That’s true, sometimes it’s like brewing beer: the material might be excellent, but the production process determines the flavor and durability.
Regarding load-bearing – I once had a Billy bookshelf that almost brought the ceiling down, and it didn’t warp at all. Then a new shelf, loaded normally, and the bottom bowed downward.
So I also suspect that manufacturing tolerances play a bigger role than many realize. Anyone who has assembled a Billy knows that the quality can vary quite a bit. So just stay a bit relaxed, there’s no need to panic 🙂
leomo
25 Jun 2018 07:19
I also find it fascinating how much indoor climate affects flooring. Especially in older buildings with fluctuating humidity levels, some shelves noticeably change over time.
A small tip from me: installing shelves with a few spacers between the side walls can help compensate for expansion and contraction.
And if you’re up for a little experiment: place a shelf board overnight in a humid bathroom and observe how the panel reacts the next day. This makes the whole process much more understandable :-)
