Hello everyone, some time ago I bought a Billy bookshelf from IKEA and assembled it exactly according to the instructions – everything is sturdy and neat. However, I have noticed that after a few weeks some of the shelves visibly warp, showing a slight sagging and a more noticeable bulge. I’m wondering: why do some BILLY shelves warp despite correct assembly? Does anyone know the reasons for this or have tips on how to prevent it? I’m particularly interested in whether the material plays a role or if environmental factors like temperature and humidity contribute more to the problem. Looking forward to your insights and suggestions!
Keatondra13 Oct 2021 09:37Hello beki3, your issue is well-known and often has several causes. Firstly, the shelves of BILLY units are usually made from particleboard or thin engineered wood panels, which makes them susceptible to moisture. Even when installation is correct, fluctuations in humidity and temperature can cause expansion or contraction, leading to warping.
Additionally, the load on the shelves is an important factor: if the shelves are often heavily packed or bear heavy items, they can bend or warp. It is also important that the shelves are reinforced at the edges with appropriate profiles or trims – if this is missing, the risk of deformation increases.
Finally, you should check whether the shelves are exposed directly to sunlight or placed in humid areas, as this accelerates warping. If you like, I can provide some tips on how to minimize this problem.
Keatondra schrieb:
For one, the shelves of BILLY are usually made of particleboard or thin wood composite, which makes them susceptible to moisture. I agree with that. I had a similar bookshelf in my bedroom where the shelves began to warp after about six months. It’s a bit frustrating, especially when you’ve assembled the shelf ‘correctly.’
What helped me was using the shelves only in climate-controlled rooms and distributing the weight evenly. Avoid overloading the shelves and put heavier books on the lower shelves. It’s disappointing because you expect sturdy furniture, but sometimes a bit of care makes all the difference.
I hope you find a solution that works for you. 🙂
Very interesting, here is a brief tutorial to understand why BILLY shelves can warp despite correct installation:
1. Material properties: BILLY shelves are mainly made of particleboard or similar engineered wood materials, which are sensitive to moisture and temperature changes.
2. Load distribution: If the shelves are overloaded or bear weight unevenly, bending can occur. This is especially common in the middle of longer shelves.
3. Installation: Even with correct installation, it is important that the shelves are perfectly level and the fasteners are properly secured.
4. Environmental factors: Humid air or direct sunlight can cause the material to expand or contract, leading to warping of the shelves.
What can be done?
- Reduce the load or distribute it evenly along the length
- Avoid placing shelves in damp rooms
- Use additional support bars or shelf brackets
- For increased stability, attaching back panels can help reinforce the entire construction
I hope this helps you and others in the forum.
What can be done?
As an addition: The issue of warping in BILLY shelves is often due to the construction and choice of materials. Particleboard swells when exposed to higher humidity, causing deformation, especially if the edges are not properly sealed.
Furthermore, there is a physical principle related to thin wood-based panels: their bending strength is limited. Overloading or uneven weight distribution increases the load beyond the permissible limit, leading to permanent deformations.
In addition, the substructure should be checked: uneven floors or insufficient horizontal alignment promote warping.
There are also tests and practical experience showing that warping can be significantly reduced by adding reinforcement with metal or wooden strips.
Lis53 schrieb:
Particle boards swell in high humidity, which leads to warping, especially if the edges are not properly sealed.This is a very important point. I would add that sealing the edges is often underestimated. The edges are the weak spots because moist air can penetrate the material most easily there.
So, if you already have shelves with slight warping, it might help to seal the edges with clear varnish or wood lacquer. This significantly reduces swelling, although it does not completely eliminate the problem.
Additionally, you should maintain consistent climate conditions and avoid placing the shelf permanently in rooms with very high humidity (bathrooms, kitchens).
