ᐅ Why do some BILLY drawers not close properly?
Created on: 20 Jun 2020 19:23
Royal4
Royal4
20 Jun 2020 19:23
I have had an IKEA Billy combination for some time now, but I’m experiencing issues with several drawers not closing properly. The drawers either stick or only close halfway; sometimes I have to press hard to get them fully inside the frame.
My question is: Why do some BILLY drawers not close properly?
I have already checked whether anything is stuck in the sliding mechanism, whether the drawers are warped, or if the installation is uneven, but I couldn’t find any obvious cause. Are there any known issues with the construction, fitting accuracy, or other components that might cause this? And are there any effective tips on how to permanently fix the problem?
Thanks in advance for your help!
pauPierce
20 Jun 2020 20:02
Hello Royal4,
Your issue with the BILLY drawers could have several causes, as the drawer runners in IKEA furniture often have a specific design that can be easily affected by assembly errors.
For better understanding, here is an explanation:
BILLY drawers are often based on simple roller or plastic runners that engage in a groove. If the runner rails are not perfectly aligned or are slightly uneven, the drawer may not operate smoothly. It also matters whether the furniture piece itself is standing level. A slight tilt causes uneven load on the roller or rail guides, which leads to misalignment.
It is also possible that the runner mechanism gets out of alignment over time or due to excessive loading. BILLY drawers often lack an integrated soft-close or self-closing function, so the drawer usually needs to be guided manually when closing. Additionally, the plastic components can become slightly warped from temperature fluctuations or wear.
A detailed inspection of the drawer runners (checking the position of the rails, possibly using a spirit level) and the function of the rollers can help identify the problem. Have you already checked whether the drawers are fully and straightly inserted? And whether the runner rails are firmly fixed or have some play?
Also: How old is your BILLY? Has the problem developed over time, or was it present from the start?
Tudogo
20 Jun 2020 20:50
Hello Royal4,
I’d like to give you a more fundamental piece of advice that often helps with IKEA BILLY:
You need to be very precise during assembly, especially with the drawers. The small white plastic rollers and guide rails are delicate. Even a slightly crooked screw or a misaligned groove during assembly can directly affect how smoothly the drawer closes.
Make sure to check if the drawers move easily on the guides without sticking. The side panels should be parallel, and the cabinet should be perfectly vertical. Use a spirit level to adjust the cabinet if needed.
If that doesn’t help, it can be useful to clean the rails and rollers—sometimes dust or wood particles settle there, especially after assembly.
By the way, removing or slightly adjusting the bump stops at the back of the drawer often improves the closing action.
I hope this helps you for now 🙂
RABLA
20 Jun 2020 21:10
most of the time, the issue is caused by improper installation or warped drawer fronts. Simply remove the drawers, check the runners, and then reinstall them properly. Make sure to align them horizontally. This usually solves the problem and the drawers will close properly again.
Foster63
21 Jun 2020 08:29
pauPierce schrieb:
BILLY drawers often rely on simple roller or plastic guides that engage in a groove.
Good point. I would like to add that I experienced the same issue with my own BILLY shelves due to minimal assembly inaccuracies. Also, the shelf base should not stand completely uneven, as this can affect the guide.
If the carcass cannot be perfectly aligned, it is helpful to use small shims or felt pads under the furniture legs. This helps distribute the load more evenly and prevents the drawers from jamming.
Additionally, it is recommended not to push the drawer closed but to guide it gently and lightly by hand. Otherwise, the plastic parts may wear out over time.
Ernesto
21 Jun 2020 09:43
Good morning,
I would like to add a few technical details here that are often overlooked:
1. Drawer fronts: In some BILLY variants, the fronts are only attached with small dowels and screws. If these are not done properly, the front can easily wobble or be misaligned, making it difficult to close.
2. Clearance in the guide systems: The plastic guides are not always play-free. If they are pressed in too tightly during assembly, they can deform slightly, which then interferes with closing.
3. Material deformation: Engineered wood products can swell or warp slightly due to moisture exposure or temperature changes. This is especially possible when the cabinet is placed in damp rooms.
4. Installation of shelves: Sometimes, when fitting the shelves, the furniture is snapped together so tightly that the whole structure twists slightly. This in turn affects the drawer operation.
I would recommend positioning the carcass with some space from the walls, adjusting shelves and fronts again if necessary, and carefully observing the closing of the drawers to identify the exact point of resistance.
