ᐅ Why do BILLY doors often creak?
Created on: 7 Mar 2021 08:12
TOKE56
Hello everyone, I have recently noticed that the doors of my BILLY shelf often creak when I open or close them. I'm wondering: why do BILLY doors creak so frequently for many users? Is this a known issue related to the hardware quality, or is it more due to the assembly, humidity, or perhaps the material itself? I would like to understand what exactly to watch out for in order to prevent or fix the creaking. Perhaps someone here has long-term experience with BILLY and knows the typical causes.
Glage
7 Mar 2021 12:10
The creaking in the Billy bookcase surprised me as well. Especially with older shelves that have been in damp rooms for years, the material becomes somewhat brittle and unfortunately experiences more movement.
It’s really a combination of material fatigue, some moisture absorption in the MDF panels, and the stress on the hinges. Regular tightening and lubrication help, but eventually, replacing the hinges is the only solution.
TOKE56
7 Mar 2021 12:43
Elias schrieb:
It is also important to retighten the screws because sometimes they loosen.
That’s a good point, thanks.
I’m wondering if the hinge design on BILLY is generally prone to this, or if there are quality differences depending on the production year? Has anyone had experience with newer models compared to older ones?
Also, I’m curious whether moisture really has such a strong impact, even though the shelf is usually placed in heated living spaces.
Seanni
7 Mar 2021 13:58
I’ve also thought that the BILLY doors just want me to visit them more often – as soon as they start squeaking, off I go! 😄
Jokes aside: Moisture can affect even heated rooms depending on ventilation and indoor climate. Wood absorbs moisture from the air, even if it’s barely noticeable, and the MDF panels can swell slightly. This shifts the alignment of the hinges, which causes the squeaking. So here’s a tip: make sure to ventilate regularly and keep up with lubrication.
ronti
7 Mar 2021 14:15
Regarding TOKE56's question: Newer BILLY shelves usually have similar hinges, so I wouldn't expect major differences.
Often, the user is the main cause of creaking, due to a lack of oil or maintenance.
Espen
7 Mar 2021 14:50
Seanni schrieb:
Moisture can affect even heated rooms.
Exactly, and on top of that, BILLY uses relatively inexpensive MDF boards. These are more sensitive to moisture and react more strongly than solid wood would.
boelnu
7 Mar 2021 15:20
One thing you shouldn’t forget: some users close the doors too hard, as if they were slamming a car door. This speeds up squeaking and gradually damages the hinge.
Maybe it’s just me, but I now try to be very gentle – this definitely helps to extend the lifespan and reduce the annoying noise.
