ᐅ Who uses KALLAX as a children's shelf, and how safe is it?
Created on: 16 Apr 2019 19:27
Anfra58
Anfra58
16 Apr 2019 19:27
I am considering using an IKEA KALLAX shelf as a children’s shelf in our living room because its size and price seem very practical. Therefore, my specific question to you is: Who uses the KALLAX as a children’s shelf, and how safe is it in terms of stability and accident risks? I am especially interested in whether the shelf is stable enough if children climb on it or use it as a play or seating surface. Has anyone had experience with tip-over protection, and what about rounded edges or similar safety features?
I look forward to factual and practical feedback so I can make a safe decision.
Dirkmin
16 Apr 2019 20:39
Hello Anfra58,
Just to be clear: KALLAX shelves are primarily designed for storage, not for climbing or as play furniture. IKEA provides an anti-tip device to secure the unit to the wall, which, when properly installed, prevents the shelf from tipping over. Without this wall attachment, the risk of accidents is significantly higher, especially with small children who might pull themselves up on the shelf.
The edges of the KALLAX are quite sharp and not rounded off, so edge and corner protectors should be considered to prevent injuries.
Recommendation: Always secure the shelf with the included anti-tip device, preferably by fastening it to the wall. If it is used as a seat or play surface, the weight and load should be monitored carefully.
To conclude: KALLAX is well suited as a children's storage unit but should not be used as climbing or seating furniture without caution. Safety must always be the top priority.
semuneo
16 Apr 2019 21:12
I also use my KALLAX as a children's shelf and have a similar view to @Dirkmin.
Dirkmin schrieb:
Without securing it to the wall, there is a significantly increased risk of accidents, especially with small children.
We attached the shelf to the wall using anti-tip straps and applied foam edge protectors. My children sometimes use it for sitting or as a step to climb, and I always make sure they are not too rough. It’s obviously not a play equipment, but with some basic precautions, it can be made relatively safe.
I also think it’s important not to overload the shelves too heavily so the weight is distributed as evenly as possible and the shelf won’t tip over.
Personally, I’ve sometimes been worried, especially seeing how children can be quite daring, but with the safety measures in place, it works pretty well. 🙂
fasau
17 Apr 2019 07:58
This is amazing—how versatile the KALLAX is!
I can only confirm this: Our little one loves her KALLAX shelf and uses it all the time to dig through books, organize toys, and yes—sometimes even to sit on it! 🙂
semuneo schrieb:
We secured the shelf to the wall using anti-tip straps and attached foam edge protectors to the corners.
We did the same, and I find the combination of sturdy wall mounting and simple padding to be very affordable and effective! Especially for families with small children, this is a great way to bring some order to the kids’ room while creating a relatively safe environment.
Please make sure to always secure shelves properly, everyone! I once read about an accident where a shelf tipped over—it can be really dangerous. But with caution, it’s a lot of fun! I’m looking forward to customizing our shelf further with colorful fabric boxes 🙂
klo40
17 Apr 2019 08:39
I would like to provide some structured advice regarding safety and practical use:
1. Wall Attachment: The anti-tip devices from IKEA must be securely fastened to a load-bearing wall (no drywall without additional reinforcement; if such walls are present, special anchors* are required).
2. Edges: KALLAX does not have rounded edges, but they are not sharp. However, I recommend attaching corner protectors for toddlers (under 3 years).
3. Load Capacity: According to the manufacturer, the shelves can hold about 13 kg (29 lbs) evenly distributed. Be cautious of loads caused by sitting or climbing attempts.
4. Load from Sitting: The unit is not tested as seating furniture. Sitting or jumping on it should be avoided to prevent damage and potential hazards.
5. Cause of Tipping: The risk often arises when children pull or climb on the top edge. Therefore, wall attachment is mandatory.
6. Additional Tips: Use boxes, toy bins, or other inserts to concentrate the weight in the lower sections. This increases stability.
In summary: KALLAX can be safely used as a children's shelf if properly secured. Using it as a play or seating furniture is not recommended for safety reasons.
Tatovin
17 Apr 2019 09:04
Hi,
I specifically recommend three things:
1. Always secure the shelf to the wall.
2. Protect the edges if small children are playing with it.
3. Do not climb on or sit on the shelf.
This helps prevent most accidents.
