ᐅ Who uses alternative door mounts for the Kallax shelving unit?
Created on: 18 Sep 2020 19:26
Alexa41Hello everyone, I’m currently looking into door mounts for the Kallax shelving unit and would be very interested to hear if any of you in the forum use alternative solutions or have even developed your own.
Specifically, I’m interested in practical and sturdy mounts that differ from the original Kallax components, so a simple retrofit without damage is desirable. I find the original mounts quite limited, especially if you want to use larger or heavier doors, or if the standard attachment doesn’t fit well with the existing furniture setup.
I’m curious about experiences with DIY models, solutions from hardware stores, or even professional alternatives that can be adapted with little effort. What about you: which materials and fastening methods have you tested? Are there solutions that are particularly reliable and durable? And how difficult or time-consuming was the conversion of your version compared to the standard Ikea mounts?
I look forward to your feedback and practical advice, as I don’t want to rush but rather remodel thoughtfully and securely.
I installed simple magnetic door catches from a third-party supplier on my Kallax.
They work well, hold the doors securely closed, and are easy to retrofit. No complicated setup, and they also look good.
Be sure to pay attention to the strength of the magnets, especially for heavy doors.
Alexa41 schrieb:
I am interested in experiences with self-built models, DIY solutions from hardware stores, or professional alternatives that can be adapted without much effort.Hello Alexa41, that is a very precise question which I am happy to elaborate on.
Many users actually take a custom approach because the standard Kallax is designed more for lightweight doors. If you want to install heavier or special doors, hinges with adjustable damping are recommended, which you can usually order separately. For mounting, many use small metal plates or brackets that can either be glued or screwed onto the side of the shelving unit—however, care must be taken not to damage the wood.
In hardware stores, you can also find door catch plates or hinge mechanisms that can be adapted. Another nice alternative is so-called push-to-open fittings if you want a handleless door. They are easy to install but require quite precise alignment.
I strongly recommend checking before the modification whether the retrofit parts fit the thickness and depth of your doors. Otherwise, rework may be necessary. Generally, metal brackets are more stable than plastic ones, but installation is usually somewhat more complex.
I have found a combination of brackets and high-quality hinges, fixed with small screws, to be effective. This distributes the load well. If you want, I can provide more detailed information.
pakokla schrieb:
Make sure to pay attention to the strength of the magnets, especially with heavy doors.I totally agree! 🙂 Magnets are really convenient, but you quickly notice when the setup doesn’t hold.
I once made something using small cup hinges from the hardware store and a simple latch that snaps into an eyelet. It works surprisingly well and even looks pretty nice, in my opinion.
Ianlau schrieb:
Many users actually take a custom approach because the standard Kallax is more suited for lightweight doors.Exactly, that’s the point! Kallax is very versatile, but there are limits. I think the key is a practical construction combined with a good eye for the materials.
With a bit of DIY effort, you can really upgrade the little shelves. My recommendation: always do a test assembly for about half an hour before fully fastening everything — that way you avoid annoying rework later. 😉
I’m looking forward to more creative ideas from you all!
