ᐅ Who has ever completely replaced their Kallax back panel with MDF?
Created on: 7 Aug 2022 17:23
Lavan
Lavan
7 Aug 2022 17:23
I have a specific question for the Kallax community here: Who of you has ever completely removed the standard back panel of your Kallax shelf and replaced it with a custom-made back panel made of MDF? I am especially interested in how you handled the mounting, whether you chose the MDF panel in a certain thickness, and of course, what advantages or potential issues you experienced with this DIY swap.
In my case, I am asking because I plan to use the shelf for heavier items, and the original thin back panel does not seem stable enough. I am also considering whether a painted or unfinished MDF panel would be better, and how that affects the appearance.
Looking forward to detailed reports, tips, and any possible pitfalls I should know about in advance. Thanks in advance!
Wesley
7 Aug 2022 18:05
Lavan schrieb:
I’m particularly interested in how you handled the mounting
Hey Lavan! I did the same myself – MDF about 6mm (¼ inch) thick, because it’s easy to work with yet still sturdy. For mounting, I screwed small brackets inside the sides and attached the MDF panel to those. No more rattling, really solid.
Lavan schrieb:
whether a painted or unfinished MDF panel is better
I painted my panel white after installation. It looks much nicer and protects against moisture. Otherwise, MDF could swell if something spills nearby.
Overall, I found the upgrade great, especially under load; it makes the shelf look much more high-quality 🙂
anken
7 Aug 2022 19:12
Lavan schrieb:
I plan to use the shelf for heavier items and the original thin back panel doesn't seem stable enough
That sounds very reasonable. MDF as a back panel is definitely more stable and increases the torsional rigidity of your shelf. It is important that the MDF board is cut to size and the edges are possibly chamfered or sealed to prevent damage. Additionally, I would recommend screwing the panel in at several points to ensure even load distribution.
A thickness of 6 to 8 mm (1/4 to 5/16 inch) seems ideal, as it is not unnecessarily heavy but still feels solid. I would avoid untreated MDF, especially if the shelf is in a room with fluctuations in humidity.
Niclas
8 Aug 2022 07:38
Wesley schrieb:
I attached small brackets inside on the sides for fastening
This is a practical solution that increases stability; however, using anchors and countersunk screws is also recommended to secure the back panel more firmly and ensure better load distribution.
anken schrieb:
the edges might be chamfered or sealed
Exactly, MDF absorbs moisture particularly strongly at the cut edges. Edge protection or sealing with paint or edge banding not only preserves stability but also improves appearance.
Practical advice: If you plan to replace the back panel, carefully check the dimensions within the Kallax frame beforehand, as slight deviations when cutting the board can cause issues later on.
fiman
8 Aug 2022 08:04
I used 8 mm (5/16 inch) MDF and attached the back panel simply with small screws and wall plugs. No special tricks, but you have to measure carefully.
rickey
8 Aug 2022 09:27
Lavan schrieb:
Looking forward to detailed reports, tips, and potential pitfalls
From my own experience, the biggest challenge was achieving an exact fit. In my case, the MDF panel ended up fitting a bit too tightly without any adjustments, causing some compression marks on the wood. It wasn’t a major issue, but it didn’t look perfect.
Therefore, I would recommend working with precise measurements and possibly rounding the edges of the panel slightly after cutting. This makes installation easier and prevents stress on the shelving unit.
