ᐅ Who else uses KALLAX as a shelving system in their camper van?
Created on: 11 Sep 2024 08:13
nuse9
I’m currently considering using the KALLAX system from IKEA as a shelving solution for my camper van.
My basic idea is to modify the KALLAX shelves to provide enough storage space, be stable enough for driving, and remain easily accessible. I’m especially curious about how other users have installed the KALLAX system in a camper, particularly regarding mounting, weight distribution, and how flexible the storage space actually is.
Has anyone had experience with this and can share whether the KALLAX unit withstands the vibrations and movement inside the vehicle?
What modifications have you made to integrate the KALLAX permanently and effectively as a shelving system in a van?
I look forward to your opinions and tips, including any experiences related to weight and stability. Thanks in advance!
nuse9
12 Sep 2024 07:42
pikin schrieb:
Basically, the KALLAX system is not designed for mobile use.
Thank you, pikin, that’s an important point. I’m particularly interested in questions about vibration and load capacity in the context of a 3.5-ton (7,700 lbs) van.
klo61 schrieb:
Rubber strips for damping are a great tip.
How exactly did you implement the mounting design? Do you use special screws? How do you prevent everything from loosening due to vibrations?
And what about the primary securing against sliding when the van brakes hard? Is screwing it to the floor enough, or have you installed additional fastenings?
gregto
12 Sep 2024 08:55
Based on many years of experience with fastening in vans, I can say: screw size 6 or 8 with metal anchors is essential, depending on the vehicle floor material.
You should never underestimate the combination of fastening both the floor and sidewalls – this significantly reduces forces during sudden braking.
Additionally, make sure to use non-slip mats between the shelf and the floor. This is often underestimated but greatly improves stability.
I also recommend avoiding a combination of only screws AND nails. Screws are much more durable under long-term vibration.
One more tip: pre-drill to prevent material cracking.
Paunon
13 Sep 2024 15:08
I have been using KALLAX in my van for two years. Pro tip: secure it additionally with ratchet straps. Screws and floor mounting alone are not enough.
Equip the compartments properly with boxes, close them, and nothing will move around. Very practical and easy to access.
