ᐅ Which versions of IKEA PLATSA come with soft-close doors?
Created on: 27 Aug 2024 19:03
Peopin
Peopin
27 Aug 2024 19:03
I’m planning to get a new PLATSA shelving unit from IKEA, but I want to make sure that the doors have a soft-close feature. I’m especially interested in which versions of the PLATSA system come standard with soft-close doors, or if there are specific door types or additional mechanisms to consider.
Are there differences between the models regarding the hinges? Is it necessary to purchase the doors or hinges separately? I would appreciate it if someone with personal experience or good knowledge could share their insights.
Thanks in advance!
Dustin
27 Aug 2024 19:47
PLATSA itself does not offer doors with integrated soft-close functionality. You need to purchase soft-close hinges separately and replace them. IKEA sells suitable dampers that can be easily retrofitted.
PeoDaniel
28 Aug 2024 08:12
Hello Peopin,
regarding your question: IKEA’s PLATSA system mainly offers two types of doors – simple wooden or cabinet doors and fronts with handles. None of these doors come factory-equipped with soft-close hinges. However, IKEA sells separate soft-close damper attachments that can be added to the existing hinges.
These dampers are relatively easy to install and work well to prevent doors from slamming and to ensure quiet closing.
If you want a complete system with soft-close functionality, you would either need to retrofit the standard doors with the dampers or use third-party hinges that have integrated soft-close. The advantage of retrofitting is that the system remains flexible and you can still use the original PLATSA doors.
If you like, I can also briefly explain how to install the dampers – just let me know!
pikin
29 Aug 2024 14:36
To summarize the question "Which versions of IKEA PLATSA offer soft-close doors?": The IKEA PLATSA system does not include doors with an integrated soft-close mechanism. Therefore, there are no versions with factory-installed soft-close hinges.
- Soft-close functionality can be achieved using separate attachment dampers, which IKEA offers separately.
- These dampers are mounted on the standard PLATSA door hinges and enable smooth closing.
- It is recommended to check the compatibility of the dampers with the hinge dimensions when purchasing.
Alternatively, you can look for soft-close hinges from third-party suppliers that are compatible with PLATSA, but these may require more effort during installation.
If you decide to retrofit, make sure the doors are well adjusted so the function can work optimally. A tip: Soft-close dampers are usually listed as accessories for the door or explicitly described as suitable for PLATSA hinges.
If you like, I can provide technical details about dimensions or installation steps.
