ᐅ Which tools should you have ready for assembling the Pax system?
Created on: 17 Feb 2020 09:37
Renra
Renra
17 Feb 2020 09:37
I am currently about to assemble an Ikea Pax wardrobe and would like to know which tools are best to have on hand to make the assembly as smooth and efficient as possible. I’m interested not only in standard tools but also in any special aids or tips that can make the process easier or help avoid common pitfalls.
I already have a basic set of tools, but it would be great if you could share from experience which tools are absolutely essential and if there are any that are useful but often overlooked. Any advice on screwdriver sizes or particular tricks when using a cordless drill would also be appreciated.
Thank you in advance for your tips!
Guyju
17 Feb 2020 11:22
Hello Renra,
Here is a more structured overview of the tools that are useful when assembling a Pax wardrobe:
- Cordless drill/driver: Ideally with adjustable torque to avoid over-tightening the screws. Many people make the mistake of using the drill at full power, which can damage the drill holes.
- Phillips screwdriver (PH2): Even if you have a cordless drill, some areas are better handled manually.
- Hammer: For dowels and small taps when fitting metal connectors.
- Tape measure or meter stick: To ensure precise alignment of the parts.
- Spirit level: To make sure the frame is not leaning.
- Rubber mallet: To protect delicate surfaces when tapping components into place.
One tip: Make sure your screwdriver bits are not worn out to avoid damaging the screws. If your cordless drill doesn’t have torque settings, be sure to screw in slowly. A small right-angle screwdriver can also be helpful when there is limited space to work.
Summary: With a cordless drill/driver (adjustable torque), screwdrivers (PH2), hammer, spirit level, and tape measure, you have everything essential to assemble the Pax wardrobe smoothly and without problems.
Good luck!
Demetrius
17 Feb 2020 12:08
Guyju schrieb:
One tip: Make sure your screwdriver bits are not worn out, or you might damage the screws.
This is really an important point that I would like to emphasize. When assembling on your own, it’s easy to feel pressured, especially when you’re short on time or need to work quickly. A worn-out tip can be very frustrating. I remember once thinking I could get by with a simple Phillips head – and then everything went wrong.
Sometimes it takes courage to take the time before starting assembly to carefully check your tools or even buy new ones. Especially with the Pax system, which is often assembled in apartments, you really want to avoid problems with screws and damaged parts.
In any case, I wish everyone here a lot of patience and success with their projects!
janfo
17 Feb 2020 12:40
- Cordless screwdriver (adjustable torque)
- PH2 screwdriver
- Hammer or rubber mallet
- Spirit level
- Measuring tape
Don’t forget a spare screwdriver. That way you’re safe.
Laukau5
18 Feb 2020 07:51
Good morning Renra,
I would like to suggest expanding the tool list from my perspective and also go into more detail on the individual work steps.
First, regarding preparation: Before assembly, it is worthwhile to lay out and check all parts to avoid searching wildly for the right wedge or wooden dowel later on. Use a clear surface with enough lighting for this.
In terms of tools, I generally recommend:
- A sturdy cordless drill with soft start and torque control. Especially with the thin particle boards, you should avoid tightening the screws too much to prevent chipping.
- Additionally, a right-angle attachment for tight spaces that are otherwise hard to reach.
- A set of hex keys (very important), since many metal connectors are fastened with hex socket screws.
- A rubber mallet, as already mentioned, for driving in dowels without damaging the surface.
- A spirit level at least 60 cm (24 inches) long, because if the cabinet is uneven, it will cause problems later when hanging doors and shelves.
The order of assembly is important: It is often underestimated that you must first align the panels precisely before attaching the back support panel. While this panel adds stability, it also restricts adjustment once screwed in.
I want to ask you: Do you plan to assemble the carcass alone, or do you have a second person? This influences the selection of tools like clamps (very helpful if you are working alone).
Finally, a small container of assembly adhesive can help if the wooden dowels do not fit tightly. This provides additional strength in the joints.
If you have any further questions about specific assembly steps, feel free to ask!
Guyju
18 Feb 2020 09:16
Laukau5 schrieb:
I have one more question for you: Are you planning to assemble the cabinet frame alone, or do you have a second person to help?
This question is very important – some steps are significantly more difficult when working alone. If you have two people, I also recommend using a battens or clamps to position and secure the parts, so your hands are free for tools and screws.
Laukau5 schrieb:
A spirit level at least 60cm (24 inches) long, because if the cabinet is uneven, you’ll have problems later when hanging doors and shelves.
I can add that I personally appreciate a spirit level with both a bubble vial AND laser function, especially on uneven floors. The small extra cost really pays off through more precise alignment.
Aside from that, a tip: Before you start, get a small bowl or box for screws so they don’t get lost during assembly. Constantly dropping screws is really annoying.
