ᐅ Which tools make assembling the Ikea HEMNES easier?
Created on: 13 Aug 2022 17:27
mangau10
mangau10
13 Aug 2022 17:27
Hello everyone, I recently purchased an Ikea Hemnes furniture piece and want to make the assembly as efficient as possible. My question to the community is: which tools are genuinely helpful and noticeably ease the Ikea Hemnes assembly? Specifically, I’m interested if you have recommendations for certain screwdrivers, cordless drills, drill bits, or other aids that not only simplify the process but also save time. Is there any special equipment that should definitely be on hand before getting started? Thanks for your tips!
Genevieve
13 Aug 2022 18:42
mangau10 schrieb:
My question to the community is: Which tools are truly helpful and noticeably make assembling the Ikea HEMNES easier?
Interesting question! Basically, you shouldn’t just blindly rely on a cordless drill, because especially with Ikea furniture like HEMNES, where the screws need to fit precisely, the torque might be set too high and could damage the material. My recommendation: a cordless drill with adjustable variable speed or a precise ratcheting screwdriver to tighten the screws controllably.
Additionally, simple aids like a rubber mallet are useful to gently join wooden parts without causing damage.
However, it depends on whether you prioritize mobility or precision. A cordless drill is faster but sometimes less precise than hand tools.
Leote
13 Aug 2022 19:08
For assembling the HEMNES, I mainly use a small Phillips screwdriver and a cordless drill with torque control. Additionally, I recommend felt pads if the furniture will be placed on laminate flooring. This helps to avoid extra work later on.
Davidleo
14 Aug 2022 08:53
I love assembling the HEMNES with a small cordless drill! It saves a lot of time and reduces frustration. My tip: use a cordless screwdriver with an integrated torque setting and LED light! This is invaluable when working in a dimly lit room. Simply very practical and a lot of fun! 😊
PULAU
14 Aug 2022 11:35
Genevieve schrieb:
My recommendation: A variable-speed cordless screwdriver or a precise ratcheting screwdriver to tighten screws in a controlled way.
I think this is very good advice. Additionally, I would like to emphasize that besides the quality of the tools, organizing the individual parts before starting assembly is crucial. Small trays or magnetic mats for screws help keep track of everything and prevent frustrating searching. The combination of efficient tools and good preparation makes all the difference.
Genevieve
14 Aug 2022 12:09
Davidleo schrieb:
My tip: A cordless drill with an integrated torque limiter and LED light!
The LED light is definitely a practical feature that is often underestimated. However, I would still pay attention to the battery strength – too weak, and the performance will decrease over time, especially on longer building projects like those with HEMNES.
Also important: Make sure not to use bits that are too coarse, as they could damage the screws.
