ᐅ Which tools are best suited for modifying IKEA HEMNES furniture?
Created on: 22 Mar 2020 08:13
ericra
Hello everyone, I am currently planning a renovation of my IKEA Hemnes shelving unit and want to customize it. I am wondering which tools are best suited for remodeling the IKEA Hemnes to achieve precise and clean results without unnecessarily damaging the material. I invite you to share your experiences, especially which tools have proven reliable for different steps (e.g., disassembly, resizing, surface treatment). Thanks for your tips!
I know how frustrating renovation projects can be, especially when you don’t have the right tools. It’s important to take your time and be realistic about what you can manage yourself. A cordless drill saves a lot of effort, but when working with wood, it’s also worth investing in good sandpaper – it often makes the biggest visual difference after cutting.
PEDRO40 schrieb:
A cordless drill saves a lot of effortI agree with you. For me, besides the cordless drill, the jigsaw was a real game changer. Especially when cutting out openings in the Hemnes shelf, I initially lacked experience. However, if you use the right saw blade, it works well.
Israel62 schrieb:
For remodeling HEMNES, you need a cordless drill, a fine jigsaw, and sandpaper.Additionally, I would like to point out that the right cordless drill should ideally have a torque-limiting setting. This prevents screws from being driven too deeply, which can damage particleboard or MDF panels.
Furthermore, good quality fine to medium grit sandpaper (grits 120-220) should be used, as coarse sanding can quickly damage the surface of HEMNES furniture.
SauDietmar23 Mar 2020 12:07Hello everyone,
I would like to contribute to the topic with a small tutorial approach:
1. Dismantling: Ideally, use a cordless screwdriver with a Torx bit for dismantling. This saves time and ensures precision.
2. Cutting: For cutting softwood (pine), it is better to use a fine-toothed jigsaw blade. Coarser blades tend to cause unsightly splintering.
3. Surface preparation: Always sand in the direction of the grain, starting with grit 120 and finishing with grit 220 or finer.
4. Drilling and new fastenings: Use sharp wood drill bits and apply light pressure to avoid splitting the material.
5. Additional tips: A sharp pencil point helps for clear marking. Always measure before sawing or drilling—measuring twice is better than cutting once!
I hope this makes your renovation easier!
ericra schrieb:
Which tools are best suited for modifying IKEA HEMNES furniture to achieve precise and clean results without unnecessarily damaging the material?I would like to add that depending on what you want to modify, specialized tools might also be useful. For example, if you want to change hinges or install new fittings, I recommend a good spirit level and possibly a cordless jigsaw kit with various blades. These will help you carry out more specific tasks more effectively and save time on rework. Good luck!
SauDietmar schrieb:
Always sand along the grain and start with a grit of 120, finishing with 220 grit or finer.This is a very good tip that helped me achieve a really smooth surface during my last renovation. At first, I was unsure because I thought it might be something only professionals do, but it’s really worth it for anyone who wants a high-quality finish.
