ᐅ Which tools are suitable for repairing cracks in plaster?
Created on: 16 Jul 2021 10:03
ROLAWSON
I am currently working on repairing Malm dressers from IKEA, specifically addressing the increasingly common issues with the drawer slides and wooden surfaces. My question is: Which tools are particularly suitable for Malm repairs when it comes to efficiently and permanently fixing both mechanical defects (such as broken screws, torn-out wood parts) and cosmetic damages (for example, scratches or small chips in the finish)? I am looking for recommendations for both DIY enthusiasts and more advanced hobby woodworkers. Thanks in advance!
emmett
16 Jul 2021 10:45
For completely broken parts, epoxy resin can help to securely bond them back together.
Danabla
16 Jul 2021 11:02
I would like to add the following recommendations:
– A heat gun is suitable for removing old adhesive residues and paint damage, but it should be used carefully.
– For chipped edges, flexible repair fillers are recommended, which can be sanded and painted after curing.
– If screws are stripped, you can use wood filler sticks or special screw extractors.
These small tools significantly improve the durability of the repair.
bupar
16 Jul 2021 11:24
That is correct. Heat guns allow you to soften adhesive and prepare the surface for re-gluing. It is essential to monitor the temperature carefully to avoid damaging the veneer.
Jonas66
16 Jul 2021 11:40
For quick repairs, I also often use paint sticks or markers in furniture wood color. This effectively hides scratches.
ROLAWSON
16 Jul 2021 12:15
Thank you for the responses so far; they already give me a good direction!
A detailed question about wood filler: Are there any recommended products that work particularly well with the typical surface of Malm dressers? And which tools do you prefer to apply filler smoothly and inconspicuously?
Danabla
16 Jul 2021 13:02
ROLAWSON schrieb:
Are there any recommendations here for specific products that work particularly well on the typical surface of Malm dressers?
Yes, I recommend water-based wood fillers that dry quickly and are easy to sand. They also have low odor. For application, small plastic putty knives with flexible blades are suitable, as they allow precise work in narrow areas.
