ᐅ Which tools are suitable for repairing cracks in plaster?
Created on: 16 Jul 2021 10:03
ROLAWSON
I am currently working on repairing Malm dressers from IKEA, specifically addressing the increasingly common issues with the drawer slides and wooden surfaces. My question is: Which tools are particularly suitable for Malm repairs when it comes to efficiently and permanently fixing both mechanical defects (such as broken screws, torn-out wood parts) and cosmetic damages (for example, scratches or small chips in the finish)? I am looking for recommendations for both DIY enthusiasts and more advanced hobby woodworkers. Thanks in advance!
bupar
16 Jul 2021 13:28
ROLAWSON schrieb:
Which tools do you prefer to use for applying filler smoothly and inconspicuously?
To smooth out the filler, I use only flexible stainless steel putty knives in various widths. These provide a consistent finish, which makes sanding easier. Afterwards, sanding with a grit between 180 and 220 is recommended, depending on the size of the damage.
nofomu
16 Jul 2021 13:45
For minor repairs, I use wallpaper filler, which adheres well to wood and is easy to sand.
ROLAWSON
17 Jul 2021 09:50
Thank you, using water-based filler sounds good. Does anyone have tips for preparing the surfaces before filling? Is sanding or cleaning necessary, and if so, what is the correct way to do it?
bupar
17 Jul 2021 10:15
The surface should be clean, dry, and free of grease. Lightly sanding with fine sandpaper (grit 180) improves the adhesion of the filler. Afterwards, thoroughly remove dust, preferably with a microfiber cloth or a soft brush.
Danabla
17 Jul 2021 11:03
ROLAWSON schrieb:
Does anyone have tips for surface preparation before applying filler?
As an addition: For painted surfaces, it is recommended to treat them briefly with a bonding primer when filling larger areas. This improves adhesion and durability.
Jonas66
17 Jul 2021 11:30
For minor repairs, I usually just clean the area with soapy water and wipe it down with a lint-free cloth before applying the filler.
