ᐅ Which tools are not necessary for assembling the IKEA BRIMNES?
Created on: 15 Jan 2023 08:17
helmut66
helmut66
15 Jan 2023 08:17
I am currently planning to assemble an IKEA Brimnes furniture piece and am wondering which tools are truly necessary for the assembly and which ones can safely be left out.
The Brimnes is relatively simple in design, but I don’t want to prepare too many tools that might ultimately not be used.
Has anyone had experience with this and can clearly say which tools are not needed for assembling the Brimnes? I’m interested in both surprising tips and the classic tools that people might mistakenly think are required.
Thank you in advance for any advice and recommendations!
toril
15 Jan 2023 09:02
Regarding which tools are not necessary for assembling the IKEA BRIMNES: IKEA generally provides the required Allen key for assembly. Therefore, the following tools are not needed:
- Cordless drill or power drill (since plastic anchors and screws can be easily fastened by hand)
- Hammer (the included plastic parts do not require any impact tools)
- Screwdrivers of various sizes (the supplied Allen key is sufficient)
The most important things are a stable work surface and some patience. So, you can manage without a large tool collection.
gadalu
15 Jan 2023 11:45
In addition to the previous post: If you still want to use a cordless screwdriver, please be careful. The supplied screws are intended for hand-tightened assembly. Applying too much force can damage the material.
Tools that are definitely not needed include:
- Pliers or pinch pliers
- Sledgehammer or other heavy striking tools
- Saw or cutting tools
These tools are unnecessary and could even damage the components. The BRIMNES uses simple connections with cam locks, which can be easily assembled using the supplied Allen key (hex key).
DEOLAU
15 Jan 2023 12:03
You don’t need a hammer.
A drill is unnecessary.
Pliers or a utility knife are not required.
Kinbu
15 Jan 2023 15:38
I would like to elaborate on which tools are not necessary for assembling the IKEA BRIMNES. The assembly of the BRIMNES is intentionally designed so that the end user can easily put the furniture together with just a few simple tools.
- The most important tool is the included Allen key. Everything else is basically unnecessary.
- Tools like a hammer or cordless drill can even be a hindrance for beginners, as applying too much force can damage the material.
- A Phillips or flathead screwdriver is also not required.
- For cutting or modifying parts, no saw or similar tool is needed either.
If you proceed slowly and assemble carefully, you can complete the process without any additional tools.
When following the instructions, no special tools are recommended.
JORDON
16 Jan 2023 07:20
Hey,
a little tip from me: If you think you need a hammer, you can safely skip it! The BRIMNES is a gentle giant – it doesn’t require any heavy-duty tools. ?
Even the cordless screwdriver takes a backseat here, as the screws are better turned by hand. This way, you protect both yourself and the furniture.
Overall, the small Allen key that IKEA provides is completely sufficient.
