ᐅ Which tools are essential for assembling IKEA Metod cabinets?
Created on: 14 Mar 2021 08:37
RapupoHello everyone, I am currently planning to assemble several IKEA Metod kitchen cabinets myself and want to be as well prepared as possible to avoid unnecessary frustration during assembly. My question is: Which tools are truly essential when building IKEA Metod cabinets? I am interested not only in the standard tools but also in tips for any additional tools that can significantly ease the assembly process. I would appreciate specific recommendations regarding types and sizes of tools, as well as advice on accessories you have found especially helpful. Thanks in advance for sharing your experiences!
Good morning! When assembling IKEA Metod cabinets, there are indeed some tools that make the process much easier. First of all, a cordless drill with the appropriate Phillips screwdriver bit is absolutely essential. While a manual screwdriver could theoretically suffice, a cordless drill saves a lot of time and effort.
For installing many Metod components, you will also need a rubber mallet, for example to gently secure dowels and other connectors without damaging the wood. A small folding ruler or tape measure is important as well, to position the cabinet units exactly or to align them properly if needed.
You should also have a spirit level on hand, especially if you are combining several cabinets, to ensure everything is straight and level. Optional: a drill can be helpful if you need to pre-drill holes or make custom adjustments.
To summarize, I would say:
- Cordless drill (with the right bits)
- Rubber mallet
- Folding ruler / tape measure
- Spirit level
For me, these tools form the essential basic equipment when assembling the IKEA Metod kitchen cabinets. If you have any questions, just ask!
- Rubber mallet
- Spirit level
Jonas66 schrieb:
I recommend magnetic screwdrivers in addition to a cordless drill and a level.That’s a very good point. Magnetic screwdrivers or bits make the work much easier, especially when working in tight spaces where you want to avoid dropping screws all the time. IKEA Metod uses many small screws, and the magnetization gives you much better control.
Jonas66 schrieb:
A file or sandpaper can also help if edges stick slightly.I agree as well. Especially with larger doors or panels, a little fine-tuning on the edges can work wonders if the parts fit a bit too tightly. However, I would only recommend doing this if really necessary, to avoid damaging the surface.
If anyone has tips for handling special connectors like dowels or burrs on the panels, I’m curious to hear them too.
