ᐅ Which storage solutions work well in Ikea Metod corner cabinets?
Created on: 17 Feb 2020 08:13
Begeon
I am currently planning my kitchen organization and have chosen the Ikea Metod corner cabinets because they offer a lot of storage space. However, I am facing the challenge of finding suitable storage solutions that fit well into the corner area while allowing efficient use of the space.
I am especially interested in proven storage options, such as pull-out baskets, rotating carousels, or special shelves that integrate well into the Metod corner cabinet. Which solutions have you used or would you recommend that are truly practical and durable? Tips for optimal space utilization and avoiding wasted space would also be very helpful.
Looking forward to your experiences and recommendations!
raquel52
17 Feb 2020 16:45
floga schrieb:
I can only recommend not to focus entirely on one solution but to combine several systems – this way, you usually find the best compromise between convenience and storage space.
I agree with this. Even though rotating carousels are often promoted, you should carefully consider space utilization. Sometimes pull-out baskets or custom-made shelves are more suitable, especially for unusually large or small items.
For durability, it is advisable to choose high-quality rails and materials since corner cabinets are heavily used.
mabla
18 Feb 2020 09:22
I installed shallow pull-out drawers in my Metod corner cabinet. Advantages:
- good overview of contents
- easy to pull out
- no more dead corner
I found rotating carousels to be too shaky and impractical for heavy pots.
Israel62
18 Feb 2020 10:50
Use simple baskets with handles instead of permanently installed systems. This way, flexibility for renovations is maintained.
Some Ikea systems can be easily adapted, but permanently mounted carousels limit options later on.
RETRAVIS
19 Feb 2020 08:35
If you want to maximize space utilization in the Ikea Metod corner cabinet, you should first determine the actual interior dimensions and door opening angles before choosing storage solutions.
With common carousel units, the maximum usable space is often less than the total volume because the turntable radius is limited. Pull-out deeper drawers with narrow heights increase flexibility for storing flat items.
An effective system combines drawers with adjustable dividers and fixed shelves for heavier objects. Ikea accessories often fit directly or can be made compatible with standard inserts.
Finally, I recommend planning with a CAD tool or online configurator to avoid purchasing mistakes and poor space utilization.
