ᐅ Which spare parts are especially important for Ikea Hemnes furniture?
Created on: 5 Jan 2021 08:37
Kaupi
Kaupi
5 Jan 2021 08:37
Hello everyone, I am currently looking into which spare parts for IKEA Hemnes furniture are particularly important and more frequently needed. Since Hemnes is one of the most popular series with many different types of furniture (cabinets, dressers, beds, etc.), I am especially interested in which spare parts should be stocked due to wear or common repair needs. It would be very helpful to have an overview of the critical components, for example hinges, screws, drawer slides, or the special dowels and connectors that IKEA uses. Any tips on the availability of spare parts and whether it is best to order directly from IKEA or if there are better alternatives would also be appreciated. Thanks in advance for your experiences and recommendations!
Far34
5 Jan 2021 09:01
The most commonly needed replacement parts for Hemnes are hinges and connecting dowels. You should also keep screws in stock, as they tend to get lost easily. IKEA sells these parts individually, which is usually the easiest option.
Deandre
5 Jan 2021 10:44
I think it makes sense to consider not only hinges and screws but also the runner tracks and drawer slides. Especially with dressers and cabinets, the hardware undergoes a lot of movement, which causes these parts to wear out over time.
Regarding your question, Kaupi: IKEA offers replacement parts directly through their customer service, although it can sometimes take a few days. Sometimes third-party suppliers online are cheaper, but the exact fit should be checked carefully, since Hemnes often uses special dowels and connectors.
One tip is to check the part number for specific connectors directly from the assembly instructions – this way you can find the right products more quickly.
ladali
5 Jan 2021 12:35
To clarify the question: "Which replacement parts are particularly relevant for IKEA Hemnes furniture?" a prioritization can be made based on the material properties and frequency of use.
- Hinges: Especially for cabinet and display case doors, as frequent use and weight load cause wear.
- Drawer slides: Enable smooth drawer operation but can become sticky or warped over time.
- Connecting elements (dowels and screws): Often lost during assembly or adjustment.
- Back panels (cardboard or MDF elements): These can deform due to moisture.
From a technical perspective, it is advisable to order spare sets together with large furniture purchases, as many fasteners are more expensive when bought later.
Regarding sources, IKEA customer service is the first point of contact; compatible replacement parts from third-party suppliers are rarely an exact fit and may cause installation issues.
V
vinli
6 Jan 2021 07:28
ladali schrieb:
Fasteners (dowels and screws): losses due to installation or readjustment are very common.
This addresses the core of the issue well. Additionally, with Hemnes beds, the slat supports (plastic brackets) are often prone to damage, especially if the bed is frequently moved or disassembled.
Similarly, when dealing with large dressers, it is important to check the back panel, as it significantly affects stability and can break if stored improperly. Therefore, it is advisable to keep back panels as spare parts if you own Hemnes furniture that is used heavily.
eldubi
6 Jan 2021 15:13
Hinges and screws are essential. If a part is broken, first check whether IKEA provides a direct replacement. If not, similar screws from a hardware store often fit.
Otherwise, especially for plastic components like guide rails or brackets, I would recommend using original parts.
