ᐅ Which replacement parts are most commonly needed for Malm?
Created on: 9 Jan 2020 08:17
BAUUS
I have a somewhat more specific question that will probably interest those who are more familiar with IKEA Malm furniture:
Which replacement parts are most commonly needed for the Malm series when it comes to repairs or upgrades?
I am interested in both typical wear parts and components that often need to be replaced during moves or regular use. Are there common weak points to watch out for?
Thanks in advance for any well-informed tips and experience reports!
mesila
10 Jan 2020 08:19
A short guide to replacing the drawer slides on Malm:
1. First, fully pull out the drawer and carefully detach the front panel (remove clips).
2. Use a Phillips screwdriver to unscrew the old drawer slides, rollers, or ball-bearing runners.
3. Align the new guide rails precisely and screw them in.
4. Carefully reinsert the drawer and check if it operates smoothly.
Common issue: Using incompatible parts or mounting too tightly can cause problems with closing the drawer.
Natan
10 Jan 2020 09:57
Interesting that many focus on the drawer slides.
However, I would like to approach the question from a different angle: Are these replacement parts really of poor quality, or is it more a matter of usage?
Does anyone have concrete comparison data on the durability of Malm replacement parts versus other similar furniture lines?
lalutau
10 Jan 2020 11:23
That is a good question.
According to statistics from furniture repair services, the high demand for Malm replacement parts is mainly due to the low price and the materials used, which are not designed for industrial heavy-duty use.
On the other hand, intensive use and improper handling also contribute to premature wear.
GU-LAU60
10 Jan 2020 12:07
So, does this mean that in the high-end segment, other parts are often more durable?
lalutau
10 Jan 2020 12:45
GU-LAU60 schrieb:
Are parts in the high-end sector often more durable?
Exactly. High-end furniture often uses higher-quality hinges and drawer slides with better craftsmanship and materials, which noticeably reduces the frequency of replacements.
LAURE-TA
10 Jan 2020 14:18
Finally, I would like to share some tips on how to find and select typical replacement parts more easily:
1. Always use IKEA original parts, as they are optimally designed for the Malm series.
2. When replacing drawer runners, pay close attention to the correct model numbers, since there are versions with and without soft-close features.
3. Browse review sites or IKEA forums; it is often recommended to order small wear parts in bulk to enable quick replacements.
For those who want to be precise, conducting a drawer runner test with load measurements can help avoid unpleasant surprises.
