ᐅ Which screws are best suited for long-term use with Ikea BESTA units?
Created on: 21 Nov 2023 16:42
minjeremi9
minjeremi9
21 Nov 2023 16:42
I am planning to use my Ikea Besta shelving unit long-term and want to make sure I choose the right screws for any future repairs or modifications. I have noticed that the screws included with the furniture play a significant role in its durability and stability, especially if the unit is frequently moved or adjusted.
Based on your experience, which screws work best for the Besta frame and fronts if the goal is maximum durability, load-bearing capacity, and safety? I am interested not only in the material and size but also in the screw type (e.g., Phillips vs. Torx), length, and possibly screws with special surface coatings to prevent corrosion.
I would greatly appreciate any advice, specific product recommendations, experiences regarding strength or longevity, and tips for installation.
Are there alternatives to the original Ikea hardware that have proven reliable over time?
Thank you in advance for your support!
Layla
21 Nov 2023 18:07
minjeremi9 schrieb:
Which screws do you find work best for the BESTA carcass and fronts, if the goal is a durable, strong, and secure assembly?
This is a really important topic, especially if you want to enjoy the furniture over the long term. I’ve tried various screws myself and can say that the standard particleboard screws that Ikea provides showed some weakness for me after a few years—particularly in areas where the shelf was moved or carried.
I would recommend using galvanized or at least stainless screws, as these are not only more durable but also resist moisture and humidity, which can often be an issue in everyday use. Personally, I’ve had good experiences with screws featuring a Torx drive; they allow for better and gentler tightening without damaging the screw head.
I noticed that some replacement screws I found at hardware stores were actually better quality than the standard Ikea ones. Of course, that doesn’t rule out other high-quality options. It’s also important not to overtighten the screws, as that can quickly damage the wood.
How do you handle the material of the fronts? Are they more particleboard or MDF carcass parts? This can also influence your choice of screws.
Lucien
22 Nov 2023 09:36
Layla schrieb:
I would recommend using galvanized or at least rust-resistant screws
That is a useful suggestion. In the specific case of the Ikea BESTA system, I recommend the following criteria for selecting screws for long-term use:
- Material: Stainless steel A2 or galvanized steel. Stainless steel is more corrosion-resistant, which is especially beneficial for indoor environments with varying humidity levels.
- Drive type: Torx screws are preferable as they allow for higher torque transmission compared to Phillips (crosshead) screws, reducing the risk of slipping.
- Length: For cabinet parts, screws with a diameter of 4–5 mm (around 0.16–0.20 inches) and a length depending on the panel thickness are suitable, typically 30–50 mm (1.2–2 inches) for BESTA.
- Thread type: Fine threads are recommended for particleboard and MDF panels to prevent splitting the material.
Regarding specific screw options: There are specialized cabinet screws, often called “Spax” screws in hardware stores, designed specifically for furniture construction. These offer better durability than standard particleboard screws.
Additionally, if frequent disassembly or repositioning is planned, consider using wood connectors or knock-in nuts to avoid material fatigue.
I also recommend checking the screws for tightness during every assembly to prevent long-term damage.
kasan
22 Nov 2023 13:02
Lucien schrieb:
In the specific case of the Ikea BESTA system, I recommend the following criteria when selecting screws for long-term use:
I basically agree, but I would like to point out that the material quality of the screws alone does not solve all problems. It is crucial how the screws are installed into the material and removed again.
I have experienced that even with high-quality stainless steel screws, frequent replacements or excessive tightening torque can damage the material around the thread. I recommend using appropriate wood thread inserts or so-called threaded bushings, which are usually made of metal and provide the wood with higher load-bearing capacity.
minjeremi9 schrieb:
Are there any alternatives to Ikea’s original hardware that have proven reliable over time?
For longer-lasting stable connections, I try to use such screwed-in metal threaded bushings whenever possible, especially in load-bearing parts of the BESTA shelf.
Finally, you should also consider whether the screws are intended for outdoor or indoor use, as some metal alloys can rust or even tarnish indoors, which looks unattractive and can weaken the material over time.
My tip: quality screws + accessories like thread inserts + correct installation and retightening = long service life.
