ᐅ Which anchors are suitable for mounting awnings on wood studs with 8 cm wood fiberboard?
Created on: 24 May 2019 12:19
KingSong
KingSong24 May 2019 12:19
I would like to install a 4m (13 feet) wide awning with a 3m (10 feet) projection on our house. Now I am considering and researching what mounting options are available. The wall structure from the outside is:
- 3mm (0.1 inch) synthetic resin plaster
- 80mm (3 inch) wood fiber insulation board
- 200mm (8 inch) mineral wool insulation
- 200mm (8 inch) timber frame construction
Of course, I would not drill into the regular exterior wall but attach the awning to the floor beam, which is located between the floors right after the 80mm (3 inch) wood fiber insulation board.
How and with what would you fasten the awning at this point?
Jörg
seat8824 May 2019 15:57
Well, simply use long thick screws directly into the wooden structure, without any dowels.
KingSong24 May 2019 16:01
Yes, definitely, but how do I bridge the 8cm wood fiber insulation? On one hand, the screws will be subjected to quite high shear forces, and on the other hand, tightening the screws could compress the insulation. I also need to ensure the whole assembly is properly sealed...
guckuck2
24 May 2019 16:15
Hm, yes, you can’t really attach anything to the insulation board, for example with a threaded rod.
I would suggest cutting out the insulation and fitting a spacer piece.
Maybe someone else has a better idea.
