ᐅ Which touch-up pens are truly effective for small scratches on KALLAX units?
Created on: 5 May 2024 19:23
Nuredin
Nuredin
5 May 2024 19:23
Hello everyone, I recently got a KALLAX shelf unit from IKEA, which has been very useful in everyday life. Unfortunately, some small dents and scratches have already appeared on the surface, which I would like to repair so the shelf looks good again and the damage doesn’t worsen.
I have considered using touch-up pens since they are practical and precise to apply. My question to you is: Which touch-up pens really work well for small dents on the KALLAX? I am mainly interested in color accuracy, but also in durability and ease of use.
Has anyone had good experiences with certain brands or products? Which touch-up pens provide good coverage and dry quickly without the repair spots standing out?
Thank you very much for your tips!
Paunon
5 May 2024 19:48
For the KALLAX shelf, the IKEA paint marker works quite well. The color matches perfectly, and it dries quickly. The important thing is to clean the area thoroughly beforehand and lightly sand it.
Jensson
6 May 2024 08:37
Hello Nuredin, I’m happy to provide a brief guide and some recommendations for using a touch-up pen on KALLAX blemishes.
1. Preparation: Thoroughly clean the damaged area with a slightly damp cloth to remove dust and grease. Then, very gently sand the spot with very fine sandpaper (600 grit or finer) to improve paint adhesion.
2. Touch-up Pen Selection: I recommend the touch-up pens from IKEA, as they are specifically designed for their furniture and match the KALLAX white tone closely. If you prefer a more professional option, Molotow or Uni-Posca pens also work well, especially for durability.
3. Application: Apply the touch-up pen in thin, multiple short layers. Allow each layer to dry completely before applying the next.
4. Finishing: After the paint has dried, you can lightly matt the surface with a very fine abrasive pad to reduce differences in gloss.
It is important not to apply too thickly, otherwise the repair will be noticeable. Good luck!
likuken
7 May 2024 14:12
Paunon schrieb:
The IKEA touch-up pen actually works quite well for the KALLAX shelf.
I see this more nuanced. Sure, the IKEA touch-up pen is convenient and matches the color, but scratches rarely fully disappear with it. Often, you can still see unpleasant spots or new chips form due to friction.
Jensson schrieb:
I recommend the IKEA touch-up pens because they are specially designed for their furniture.
That is not wrong, but especially if you are aiming for durability, I would rather use carpenter's or automotive touch-up pens. These are more expensive and a bit more complicated to apply, but much more robust.
I even claim that many people rely too much on touch-up pens, although a thin layer of high-quality repair paint or even a suitable marker for wood decor often works better.
So, if you value a truly long-lasting result, you will end up somewhat disappointed with the "standard" touch-up pens.
