ᐅ Which types of paint are especially suitable for long-lasting finishing of Ikea Besta furniture?
Created on: 31 Oct 2018 08:27
Gumau4
Good morning everyone,
I recently bought some Ikea Besta furniture that I would like to enhance with a durable and visually appealing paint finish. I am looking for paint types that not only adhere well but are also scratch-resistant and moisture-resistant, as the furniture will be placed partly in the living room and partly in slightly more humid areas.
My specific questions:
- Which paint types (brands / variants) are especially suitable for Besta furniture made of MDF and wood fiberboard?
- Are there any special pretreatments or primers that help the paint last longer?
- Which type of paint (e.g., acrylic paint, polyurethane paint, alkyd paint) do you recommend based on your experience?
- What is the best approach to achieve a smooth and durable finish?
I look forward to your combined expertise and tips, especially regarding which paints have made your furniture look great and last long.
Thank you in advance!
barda6
31 Oct 2018 13:33
jelite schrieb:
Common mistakes:
- Applying layers that are too thick, which causes long drying times and may lead to peeling.
Exactly. Also, make sure the paint dries free of dust, otherwise there will be unevenness. Apart from that, everything is as mentioned above.
lukin
31 Oct 2018 14:45
pikin schrieb:
Acrylic paint is UV-resistant, which is an advantage for living room furniture.
I can only confirm this. UV resistance ensures color durability over many years.
The note about primers is also important—especially for Besta. Some users underestimate the effect of primer and then complain that the paint peels off immediately.
I would like to add a tip: after the first coat of primer, let the material dry thoroughly for at least 12 hours.
theota
31 Oct 2018 16:18
I find this fixed recommendation of acrylic paint somewhat one-sided. PU (polyurethane) coatings are by no means only for professionals. Sure, they have a stronger odor, but when it comes to long-lasting durability, you shouldn’t be overly cautious.
For frequently used furniture, such as kitchen cabinets, the extra effort is worthwhile. Criticism regarding curing times and smell is often exaggerated and not an issue with proper ventilation.
So, my point is: if you want longevity, go straight for PU coating rather than acrylic paint. The finish is more durable and more resistant to scratches and moisture damage.
Of course, with proper preparation and primer, as described.
Just my opinion, but I think the supposedly simple solution is sold too often here.
pinJustin
31 Oct 2018 16:45
PU paint is fine, but only if you have experience with spraying or rolling; otherwise, the surface will become uneven. For beginners, acrylic paint plus a primer usually suffices.
It’s better to work neatly and be patient.
PEDRO40
31 Oct 2018 17:59
I understand that choosing the right paint color can be frustrating. I had issues with chipping myself until I switched to acrylic paint with a primer – that really put my mind at ease.
Besides the technique: Take your time and always let everything dry completely. I’ve learned that patience makes all the difference. This way, your Ikea Besta will be truly durable and also look great.
Looking forward to hearing how it goes for you.
Gumau4
1 Nov 2018 08:11
lukin schrieb:
I have had good experience with acrylic lacquer myself – the finish is high quality and the colors stay vibrant for a long time.
Thank you for your detailed explanation, lukin. Could you please share more about the surface hardness of acrylic lacquer compared to polyurethane lacquer, especially regarding Besta furniture? Does acrylic lacquer really hold up to everyday use, particularly if children handle the furniture more roughly?
Thanks in advance!
