ᐅ Which Ikea Pax storage systems are suitable for office supplies?
Created on: 14 Oct 2020 07:38
Jeremiahfi
I am planning to use the Ikea PAX storage system to organize office supplies in my home office. I am wondering which specific PAX modules and interior fittings work best for different types of office materials – for example, file folders, writing instruments, electronic devices like printers or scanners, as well as paper, folders, and smaller office accessories.
Which PAX combinations or internal drawers would you recommend for creating a clear and functional storage solution in an office setting? Are there differences between the various PAX widths or heights that should be taken into account? I’m also interested in any practical tips on how to organize the interior of the PAX units to make the most of limited storage space.
Thank you in advance for your expertise and experiences!
Besides the dimensions, the choice of materials is also important in the Pax system: glass doors allow a clear view of the cabinet's contents but offer less privacy. For a balance between privacy and easy access, I recommend wooden doors with integrated handles.
Regarding interior fittings:
- I use VARIERA insert boxes for writing utensils,
- baskets are suitable for cables and other accessories,
- for better organization, I recommend pull-out mesh baskets, as they improve visibility and can be easily removed.
By customizing the system well, even smaller notes and documents can be neatly labeled and stored.
barEsperan14 Oct 2020 14:45The PAX drawers with soft-close function are affordable and ideal for office supplies because they operate quietly and smoothly. For folders, I recommend adjustable shelves.
You can also create cabinet divisions with separators to separate books and paper.
A very important point to consider is the load capacity of the individual shelves and drawers from the PAX system. Especially for devices like printers, scanners, or large binders that are fully loaded, it is important to check whether the maximum load of the shelves is not exceeded.
The official data from Ikea states that shelves in PAX wardrobes have a load capacity of around 25 kg (55 lbs), which is sufficient for most office supplies. It is recommended to place devices on lower levels to ensure stability.
Furthermore, if drawers are used frequently, it is advisable to opt for metal drawer slides with soft-close to minimize wear. My tip for more ergonomic use is to install pull-out work surfaces in some PAX modules, which can serve as temporary workspace.
I would like to know how much volume you have available and which materials you value most – then the planning can be even more precisely adjusted.
SauDietmar15 Oct 2020 08:55For planning an efficient office supply storage system in PAX cabinets, I usually proceed as follows:
1. Paper and folder organization: Use at least two to three adjustable shelves with a depth of 58 cm (23 inches) for standard folders.
2. Small items: Use VARIERA boxes and inner drawers to prevent dust buildup and keep things organized.
3. Electronic devices: For the printer and scanner, either an open compartment or a platform is recommended to ensure devices are easily accessible and well ventilated.
Common mistakes:
- Placing shelves too close together so folders don’t fit
- Not using dividers or organizing systems
- Positioning devices too high, which reduces stability
Summary: A practical combination of shelves, drawers, and possibly hinged or swing doors provides the best outcome.
Common mistakes:
Wyatt schrieb:
A very important point to consider is the load capacity of the individual shelves and drawers in the PAX system.Exactly, many people overlook that. The construction and load limits should always be planned for to prevent damage later on. Another tip: Using metal shelves instead of wood for heavier items significantly improves stability.
Jeremiahfi schrieb:
Are there any recommended door or lock options from Ikea that can be combined with the PAX system?As an additional note: For closures, using magnetic or latch locks (sometimes from the kitchen section) is advisable – functional and affordable. It is important to ensure the door modules fit perfectly so the locks operate correctly.
Conclusion: Combining proper load management with lockable doors makes the PAX system a flexible storage solution for office supplies, also considering security aspects.
