I have a quite specific question about the Ikea Pax wardrobes and hope to find some expert knowledge here.
I am interested in which Pax components are the easiest to replace in practice, especially regarding shelving parts (e.g., interior shelves, panels, drawers) as well as exterior elements like doors or frames.
My concern is whether there are structural differences among the various Pax versions that make replacement easier or more difficult. For example, if some shelves are built more modularly so that individual parts (such as shelves or drawer components) can be quickly removed and replaced without having to dismantle the entire unit.
Can anyone share their personal experience on this? And are there any recommendations on which Pax models are particularly advantageous if you value easy adjustability?
Thanks in advance to everyone who shares their tips and experiences!
NOLEO43 schrieb:
I'm interested in which Pax components are the easiest to replace in practice, especially regarding shelving parts (e.g., interior shelves, panels, drawers) as well as exterior elements like doors or frames.That’s a really good and quite complex question. I think it depends a lot on the specific system and generation of the Pax unit. With my old Pax (over 10 years old), replacing interior shelves and panels was very straightforward since everything used simple brackets. I was even able to add extra shelves later on without changing the whole structure.
With newer models, however, I got the impression that some elements are more permanently fixed, so swapping individual parts involves more effort. That also held me back a bit because I was worried about compromising stability if I took too much apart.
Another thing that helped with my old Pax: the doors had standardized dimensions, making replacements relatively flexible. But be careful, this does not apply to all doors, especially not for custom front designs or colors.
In short: when buying, you should pay close attention to the construction and connection methods used if you want flexibility for future modifications.
How about you? Have you ever encountered a similar issue?
Interior floors and hanging panels can usually be replaced easily. Doors often come in standard sizes, but can be more challenging with special fronts.
Frames and sidewalls are usually fixed components and more difficult to replace directly; in these cases, it is generally better to replace the entire module.
Henry schrieb:
With my old Pax (over 10 years old), replacing the interior shelves and boards was super simple because everything was secured with basic brackets.This matches my observations as well. There are some fundamental construction principles within the Pax system that vary from one generation to another. Generally:
- Interior shelves are secured with metal pins or plastic clips, allowing for quick replacement.
- Drawer systems are usually pre-assembled and can be removed from the cabinet depth adjustment without disassembling the entire unit.
- Doors: Standard models can be replaced without major issues, but hinges and mounting points vary depending on the model year.
- Side panels and frames are typically fixed and serve as static load-bearing parts. Replacing them usually requires swapping out the entire cabinet carcass.
It’s also worth reviewing the respective assembly manual as a PDF before purchase, since it shows the construction and helps to assess what can be replaced.
Summary: If interchangeability is an important criterion when choosing a Pax system, focus on the internal modular components (shelves, boards, drawers), as these are the easiest to remove and replace, while the outer structure mainly consists of fixed elements.
