ᐅ Which Ikea Pax furniture pieces are suitable for small children's bedrooms?
Created on: 16 Jan 2017 13:27
madraHello everyone,
I am currently planning the furnishing of a rather small children's room for my approximately 5-year-old child. Since the space is limited, I am looking for Ikea Pax furniture that is especially suitable for small rooms while still offering enough storage and safety for children. Important aspects for me are child-friendly height, safe handles, flexible adjustable interior fittings (e.g., for clothes, toys), and durable materials that are also suitable for children’s use.
I am particularly interested in which Pax models and combinations have proven effective in small children's rooms, how you make the best use of the furniture, and whether there are any special considerations regarding assembly or storage solutions that I should be aware of.
Thank you in advance for your informed experiences and tips!
madra schrieb:
Since the available space is limited, I’m looking for Ikea Pax furniture that is especially suitable for small rooms while still providing enough storage and safety for children.Basically, when selecting Pax for small children's rooms, it’s a good idea to choose narrower wardrobe widths. Ikea, for example, offers 50cm (20 inches) wide wardrobe frames, which, due to their slim design, fit well into small spaces without being too overpowering.
I also recommend using doors instead of drawers, as they save space and are easier to operate—this is particularly important for young children! For the interior fittings, you should set shelves and, if needed, clothes rails at child-friendly heights so the storage can be used effectively and your child can later reach their belongings independently.
Regarding safety: the handles used are generally sturdy and rounded, which helps prevent injuries. Additionally, I strongly advise securing the wardrobes to the wall (using Spax screws or Ikea-specific fixings), since Pax units can be quite tall and need to be stabilized to avoid tipping.
One more tip: if you need storage for toys, the inserts with drawers are a great option, allowing flexible organization and helping keep things tidy.
If you like, I can also share the exact configuration I used in a similarly small room.
Here is a structured approach for you, madra, to help you select the Ikea Pax models based on your requirements:
1. Room measurement: Measure the exact space available for the wardrobe. Also consider door openings and traffic flow within the room.
2. Frame width: For small children’s rooms, I recommend a 50 cm (20 inch) frame width, as Renla47 already mentioned. These usually fit well even in narrow recesses.
3. Height: Pax wardrobes come in different heights, typically 201 cm (79 inches) or 236 cm (93 inches). The lower option is often sufficient for children’s rooms and easier to assemble.
4. Doors vs. drawers: As mentioned earlier, doors save space, while drawers provide good access. Drawers installed at a low height are especially ideal for children.
5. Interior configuration: Use the adjustable inserts to combine shelves, hanging rails, drawers, and storage boxes so your child can later keep things organized independently.
6. Materials and safety: Ensure secure assembly; always anchor the wardrobe to the wall. Avoid sharp edges; Pax edges are generally rounded and child-friendly.
Summary: A 50 cm (20 inch) wide, 201 cm (79 inch) high Pax with 2–3 doors, combined with a mix of shelves and low drawers, is usually the ideal solution for a small children’s room.
If you want to decide on a specific setup, I can gladly suggest a detailed planning sketch.
farkin schrieb:
A 50cm (20 inch) wide, 201cm (79 inch) high Pax wardrobe with 2-3 doors, combined with a mix of shelves and low drawers, is usually the ideal solution for a small children’s room.I have to jump in here – especially for children’s rooms, I find the option to use colorful inserts (e.g., colored boxes or handle strips) unbeatable. This way, tidying up really becomes fun and is more likely to be seen by the child as a game.
Also, if space is really limited, the “sliding door Pax” can be a great alternative because the doors don’t swing inward or outward, so you always have enough room to move around. Sure, the installation is a bit more complex, but it’s definitely worth it if you want to stay flexible.
By the way, the height of 201cm (79 inch) you mentioned is perfectly fine – but make sure your child can easily reach the lower levels. A full-height wardrobe can be too much if it’s mainly used for clothes and toys stored at lower levels.
The most important thing: Don’t try to plan everything at once; instead, start modularly. That way, you can add more storage later if needed.
