ᐅ Which Ikea Pax doors are particularly resistant to scratches?
Created on: 16 Aug 2024 07:38
michelena
michelena
16 Aug 2024 07:38
I am planning to buy an IKEA PAX wardrobe and am especially looking at the different door options. My main question is: Which IKEA PAX doors are particularly resistant to scratches?
I am mainly interested in which materials or surface treatments on the doors offer the best protection against superficial scratches—from everyday use, moving furniture, or minor impacts with household items.
Does anyone have specific experience or can say whether, for example, high-gloss lacquer, melamine coatings, or foil-covered doors provide advantages here? Or are doors with real wood veneers better or worse in terms of scratch resistance?
I am looking for a long-term solution that also remains visually durable and requires little maintenance. Any tips on alternative options or experiences with different door types in the PAX system would really help me make a well-informed purchase decision.
Thanks in advance for your input!
pikin
16 Aug 2024 09:41
In general, doors with a melamine resin coating tend to have higher scratch resistance compared to painted high-gloss surfaces. Melamine is more durable against mechanical wear and is also easier to maintain.
Foil-covered doors can vary in scratch resistance depending on quality but are often less robust than melamine. Veneered doors look more premium but are more vulnerable to scratches because the real wood veneer is thin and not easy to repair if damaged.
For a long-lasting solution, I recommend doors with melamine coating (for example, the "Fardal" series at IKEA). These are especially resistant to minor scratches and can handle everyday wear and tear well.
Domau0
17 Aug 2024 11:03
pikin schrieb:
In general, doors with melamine resin coatings show higher scratch resistance than painted high-gloss surfaces.
I agree with this and would like to elaborate a bit:
Melamine resin coatings are a type of thermoset surface that is very hard and resistant to abrasion. The plastic layer is pressed onto a substrate panel under heat and pressure. The surface hardness is significantly higher than that of paints, which are often more prone to scratches, especially in the high-gloss range.
High-gloss paint, which is also offered for PAX doors (e.g., "VOXTORP"), has a very attractive appearance, but small scratches tend to appear quickly in everyday use. This is partly because, although the paint consists of multiple layers, it is still more vulnerable to mechanical impact or dust particles from clothing.
Veneered doors (e.g., "HAMMARP") offer a natural look but are more sensitive to scratches due to the thin real wood layer, which is harder to repair. It should be noted that special wood care products are available to conceal minor scratches, but this requires maintenance effort.
I would be interested to know more about your usage situation—for example, do you live with children or pets, and will the wardrobe be placed in a high-traffic area?
The more intensive the use, the more it speaks in favor of the more durable synthetic surfaces (melamine). If you decide on high-gloss, the scratch sensitivity can be somewhat reduced by careful handling and suitable care products.
BARSAN
18 Aug 2024 14:29
Domau0 schrieb:
The higher the load, the more it speaks in favor of the more durable synthetic surfaces (melamine).
Exactly. Melamine is the most resistant.
Recommendation: FARDAL doors.
They are easy to clean and require very little maintenance.
