ᐅ Which IKEA Metod cabinet front materials are especially scratch-resistant?
Created on: 6 Oct 2022 10:13
PAUCURT
PAUCURT
6 Oct 2022 10:13
I am planning to equip my kitchen with the Ikea Metod system and am currently comparing the front panel materials. I have the question: Which of the available Metod front materials are particularly scratch-resistant?
It is very important to me that the fronts maintain their appearance during daily use, as I know from experience how quickly kitchen fronts can develop small scratches or signs of wear.
Does anyone have reliable information or personal experience regarding the scratch resistance of the various Metod front materials, such as lacquer, foil, real wood, or glass? Which materials are truly durable, and what should I pay attention to when purchasing if I want maximum robustness?
I look forward to your detailed assessments and tips.
Thierryzar
6 Oct 2022 11:07
With Metod fronts, the foil surface is the least scratch-resistant. Painted fronts with a matte finish perform significantly better, especially when they are painted multiple times. Glass fronts are the most durable, although they are also sensitive to impact.
TEBILO
6 Oct 2022 12:34
The scratch resistance of Ikea Metod fronts depends heavily on the material used and the surface treatment. Generally, there are the following types:
- Foil fronts: These are glued or laminated onto MDF. The foil itself is relatively thin and not very durable. Small scratches become visible quite quickly. Bowls or sharp objects, in particular, can damage the surface.
- Painted fronts: These are coated several times, creating a protective and relatively hard surface. Depending on the paint finish (matte or glossy), there are slight differences in scratch resistance. Matte painted fronts often show scratches less clearly, while glossy ones can appear more sensitive.
- Real wood fronts: Solid wood is stable, but the surface can still get scratched if not cared for properly, especially with veneered fronts. The susceptibility also depends on the wood type and the sealing used.
- Glass fronts: Glass fronts are highly scratch-resistant compared to standard kitchen fronts. The material is hard, but there is a risk of chips or breakage from heavy impacts. Additionally, fingerprints are more noticeable.
If you are looking for high scratch resistance, I generally recommend painted fronts or glass fronts. Proper maintenance is also important: fronts should be cleaned with soft cloths and suitable cleaners.
If you want, I can provide more detailed information about the individual manufacturing processes. Also interesting: What kind of kitchen usage do you expect specifically? Will the surface be mostly exposed to children, pets, or heavy cooking activity?
nojaus
6 Oct 2022 13:10
I totally understand how frustrating it can be when scratches affect a beautiful kitchen. At my own home, I have matte painted Metod fronts, and even though I’m careful, smaller scratches have appeared, but they aren’t too bothersome.
You can tell that the material is quite durable compared to larger kitchen fronts covered with laminate or foil. From my experience, my friend’s foil-covered fronts often get small dents and marks, which I see much less frequently with painted fronts.
Maybe a useful tip would be to protect smaller areas, for example with handles, to avoid direct contact with sharp objects when possible.
Espen
6 Oct 2022 14:05
The painted fronts with a matte finish are a reliable choice for scratch resistance.
Foil scratches easily, and glass is sensitive to impacts.
If you want the most scratch-resistant fronts, choose either matte painted or glass.
Palenar
7 Oct 2022 08:47
Additional information:
Metod fronts with real wood are visually very attractive but have certain limitations in terms of scratch resistance. Real wood fronts are often coated with a thin layer of lacquer or oil, which protects against moisture but is not as mechanically durable as lacquer or glass.
The wood itself can develop dents and scratches from normal kitchen use. The advantage here is that these signs of wear often create a natural patina, which some users find charming and gives a lively appearance.
Painted fronts are usually made of MDF coated with several layers of paint—often polyurethane (PU) lacquer—that is long-lasting and resistant to scratches. However, depending on the quality of workmanship, scratches cannot be completely ruled out.
Glass fronts stand out due to their high scratch resistance, as glass is hardly scratched during everyday use. However, it should be noted that glass fronts are more sensitive to impacts and require more careful cleaning because fingerprints are more visible.
Foil is mainly offered by IKEA as a budget-friendly option but is better suited for light use.
Perhaps you could clarify how heavily your kitchen will be used? For example, is the kitchen furniture normally in a single-person household, or are there children who use it? Such factors can influence the choice of materials.
